diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Tubes / Valves (http://www.diyaudio.com/forums/tubes-valves/)
-   -   Over-Spec'd PT as replacement. (http://www.diyaudio.com/forums/tubes-valves/207776-specd-pt-replacement.html)
MellowTone 29th February 2012 12:31 AM
A friend of mine has a Line 6 Spider Mk II tube head, which is USA-spec. Using this in Australia requires a stepdown transformer. He would like to be able to use this straight off the mains without need for lugging around a stepdown.
I have confirmed the transformer is NOT universal primary (supports 115/120V operation, but not 230/240V)
He'd be looking at around AUD$220 for replacement Line 6 tranny at 240V, which is higher than he wanted to pay. I happen to be doing an order of transformers soon (probably from Edcor) and thought I might get a custom replacement for the PT in his Line 6. Line 6 have declined to divulge
Secondaries required are 6.3V (heaters) 9.8V (on board solid state effects) 60V (bias) and 340V (B+)
Which brings me to my question. Looking over the amp, I can estimate what current required on each tap, and I was planning to simply take my estimate, then add something in the order of 30-50% as a buffer to ensure it has enough current.
To my knowledge, this should not have a detrimental effect on the amp (having the correct voltages but at higher than required amperages) - can anyone confirm?
leadbelly 29th February 2012 03:46 AM
Originally Posted by MellowTone (http://www.diyaudio.com/forums/tubes-valves/207776-specd-pt-replacement-post2927174.html#post2927174)
It can if you overdo it. Google "transformer regulation curve" to understand why. If you don't overrate too much you should be fine.
EDIT: if it were me I would probably try to fit a 240:120 autoformer inside. Reversible, cheap, lower risk. Of course you have to find one sized correctly first.
MellowTone 8th March 2012 11:16 PM
Originally Posted by leadbelly (http://www.diyaudio.com/forums/tubes-valves/207776-specd-pt-replacement-post2927339.html#post2927339)
Interesting read.
Yes, we're currently trying to decide which option is best.
Although it did just occur to me that I do have access to the amp, so I'll connect up a dummy load, crank it and check how much current it's pulling on each winding.
Why I did not think of this before, I do not know.....
counter culture 9th March 2012 01:46 AM
Tube instrument (guitar) amplifiers get their tone (partly) from having mildly underspec PTs.
Look for the Hartley Peavey Whitepapers on the Peavey site under support/technotes. I think 'Transtube' is the relevant one.
Resources saved on this page: MySQL 18.75%
