diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Tubes / Valves (http://www.diyaudio.com/forums/tubes-valves/)
-   -   pp KT88, IT phase splitter (http://www.diyaudio.com/forums/tubes-valves/207770-pp-kt88-phase-splitter.html)
tim614 28th February 2012 11:01 PM
2 Attachment(s)
after a long year, i just now got one "some what" button up so here's the update.
PP KT88 IT phase splitter MONO BLOK, cathode bias for now, 6n6p driver tube.
B+1 = 573v
cathode V = 63v (573v-63v = 509v plate Voltage) @ 126ma / 2 = 63ma per tube.
B+2 = 123v
cathode v = 3.39 @ 23ma
im hoping this is pretty close to my goal of running class A.
if im missing something please let me know.
as of firing it up there were no hum what so ever, sounds clean and tight, i only play it long enough for testing.
BTW: i hve the tube rec on pic but are using Solid state Rec for now, have not yet decide till its all done.
HollowState 29th February 2012 01:15 AM
That's a very nice looking amplifier. A traditional style that's right up my alley. But in my book, 500 volts at 63mA is class AB not A, assuming you're talking about the output stage. You would have to increase the current substantially and lower the voltage to run class A and stay within the KT-88's dissipation. But that sort of defeats the advantage of a PP output stage.
tim614 29th February 2012 02:36 AM
Thanks hollow!
Well AB it is, I'm not too worry about it being class a, just wanted to build a bad *** pp amp.
Being new at this I want to confirm with the fellow diyer.
overtheairbroadcast 29th February 2012 03:36 AM
That is a very contemporary design and look you have going on there. It's a great balance with the tubes.
tim614 29th February 2012 03:57 AM
Thanks!
I'll post my progress as I go
jam 29th February 2012 04:59 AM
Tim,
Nice looking design.
Any schematics possibly for us to look at?
Jamv
tim614 29th February 2012 12:42 PM
this amp is base on the andrea ciufolli shchematic on audiodesignguide
Globulator 29th February 2012 05:53 PM
Can you post up the picture here please?
Also what does the meter measure?
tim614 29th February 2012 06:21 PM
1 Attachment(s)
the meter is "bias meter". the amp is Cathode bias right now but will be "Fix bias" as soon as i get the pair build.
Push-Pull Amplifier
tim614 10th May 2012 01:01 PM
update
2 Attachment(s)
finally got them hook up, been playing for about a month now (50-60hrs) sound very good so far.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
