pp KT88, IT phase splitter
Old 10th May 2012, 03:03 PM   #11
matejsirk is offline matejsirk  Slovenia
Hi Tim,
which interstage transformers do you use?
Old 10th May 2012, 04:03 PM   #12
tim614 is offline tim614  United States
tim614's Avatar
Lundahl 1660
Tim
" perfect imperfection "
Old 9th November 2012, 12:36 PM   #13
Osirison is offline Osirison  Netherlands
Thank you all for the great comments!
@Tim, Very nice amplifiers you got there thanks for sharing the pictures, schematics look very simple, just what I need for a starter amplifier and with no negative feedback
Anyone know more about rectification?
@Eli Duttman wrote that I could get slight more bass from using diode's instead of tube.
Is there more I should know about this? i'm not sure yet whether I should go for silicon or tube rectifier.
@TheGimp, I'm going to drive Bowers & Wilkins CM7 loudspeakers I just like to have some overkill in the amplifier.
I'm not listening loud, and lots of music styles so I want an amplifier that is not limited since i'm going to build it why not have some power reserve
Old 9th November 2012, 12:59 PM   #14
overtheairbroadcast is offline overtheairbroadcast  Canada
Hi Tim,
What is the tube amp hiding out underneath? The Mikael Abdellah KT88 SE Amp? Other than power, how does the sound compare between PP and SE in you room?
OTAB
Old 9th November 2012, 06:47 PM   #15
tim614's Avatar
The pp are now playing for about 6 month and are not tube rec anymore, I use solid state diodes and like it better, as for the amp underneath its indeed the abdellah design. I don't have the SE kt88 anymore it found a new home.
The difference in sounds between the two amps to me is that the SE have a slight mellower sounds, the PP just rocks!
Tim
Old 9th November 2012, 07:39 PM   #16
tim614's Avatar
Default it cant get any simpler than this
wiring are as simple as it can get
Tim
Old 9th November 2012, 07:43 PM   #17
tim614's Avatar
pic
Tim
Old 10th November 2012, 12:58 PM   #18
tim614's Avatar
Default Pic
Yamaha ns1000, drd 300b, pp kt120
Tim
Old 29th November 2012, 06:50 PM   #19
farkincza74 is offline farkincza74  Hungary
Default speaker
Hey!
What kind of speakers are there?
They are beautiful!
Old 17th March 2013, 08:00 PM   #20
Jaimo is offline Jaimo  Canada
Default how does the amp measure?
Originally Posted by tim614 View Post
finally got them hook up, been playing for about a month now (50-60hrs) sound very good so far.
I am tempted to build this amp- will do more research first. Have you done any measurements?
pp KT88, IT phase splitterHide this!Advertise here!
Phase Splitter Stretto Solid State 2 5th August 2011 11:26 PM
Phase Splitter Help famousmockingbird Tubes / Valves 16 10th May 2011 09:40 PM
Need help on phase splitter guwakzhai Power Supplies 7 23rd December 2010 05:51 PM
Optimizing a 807 PP amplifiers input stage and phase splitter... pauldune Tubes / Valves 4 26th November 2009 10:24 PM
HELP; DIY PP amp - it's phase splitter, or buy Chineese. WE91 Tubes / Valves 19 30th October 2007 04:01 PM
