YAQIN MS-22B. Any thoughts, please? - diyAudio
Old 28th February 2012, 05:53 AM   #1
vincula is offline vincula  Spain
Default YAQIN MS-22B. Any thoughts, please?
Hi everybody,
Hope this is not "just another thread" on a Chinese phono pre. I need some impressions on this phono alu-shoebox. I'm considering buying one to go along with a Nagaoka MP20 in a 2nd system upstairs.
I've been reading about it. Some say it's only a solid state amp with a pair of bulbs to impress audiophools. Others seem to be really pleased with the sound, which may be all that matters, I s'ppose. Not lots of info though. Some pics of its guts or an schematic would be most welcome. Recommendations of similar preamps too!
Thanks in advance for your help and dedication!
Vinc
Old 29th February 2012, 04:40 PM   #2
Any ideas? I've been reading it's a hybrid circuit, probably filled with cheap components, though one never knows and it can be modded. I recently had the opportunity to listen to a Yaqin 2000 hybrid amp and it was mind-blowing...
Vincula
Old 29th February 2012, 05:47 PM   #3
Any reason you've decided on this over the Yaqin ms-12B? Don't know much about the 22B, but there's lots of info available for the 12B. Like here!
Old 29th February 2012, 05:48 PM   #4
Globulator's Avatar
Dig out the schematic and post it up here!
If it's designed properly if should sound good, but the Moskido on here sounds like a much better bet for sound and quality TBH.
Old 29th February 2012, 06:02 PM   #5
Well, I just need a phono preamp to go with a Vincent Av 382 in the living. I thought about the MS 22B over the MS12B 'cause it's simpler and smaller. Samsung LCD, bluray player, and three kids. You get the picture. The only hi fi attraction for daddy would be a phono pre and my beloved TT. Must move my main system into my bedroom.
I love valves and would like to soften things a bit. Got a well-spec'd Audio Innovations 500 with a nice onboard phono section based around a couple of 12AX7's (actually some great 5751 NOS Sylvania) and I really enjoy it.
What's about that Moskido pre? I'm open to suggestions. Just have to keep my budget low -guess you've been reading about Spain lately, haven't ya? If not, you all should...
Thanks in advance!
Vincula
Old 21st April 2012, 09:14 AM   #6
Jadran's Avatar
Thanks in advance!
Vincula
You've probably already found solution, but if you didn't you might look at Hanss MM/MC preamp. There is only one left on eBay at reasonable (low) price of $109 + 23 shipping. I believe it's much better than Yaqin 22B (that is also non-tube device) and cost less. I just bought one to try, while Yaqin MS12 I already have will need some new and better capacitors and resistors
cheers
Old 14th June 2012, 01:17 PM   #7
I have the schematic of the ms-22b, and I own this phone pre. I changed the entire components...available...
Now the sound is open and bright.
Old 9th August 2012, 09:32 AM   #8
Hey, do you have photos or the description of what you changed?
Old 24th August 2012, 02:08 PM   #9
certo che si...
Old 24th August 2012, 02:20 PM   #10
Ok, can you please post them and tell us the list of components changed ?
Yaqin MS-20L tube recommendation cyto Tubes / Valves 4 25th April 2013 06:27 AM
Help - YAQIN MS-20L schematic pigeon_snake Tubes / Valves 4 11th January 2012 12:49 AM
Yaqin MS-12B output awkwardbydesign Analogue Source 0 13th November 2011 11:37 AM
Yaqin MS-300B SET amp Rodango Tubes / Valves 18 26th November 2010 08:09 AM
Help - MS-6V6 Yaqin schematic wfmali Tubes / Valves 5 6th April 2010 07:55 PM
Copyright 1999-2017 diyAudio
