This is a very simple and low cost headphone amplifier which can also be used as preamplifier. The total cost of the 3 tubes used in this design is less than $10.
2 troids in one 6N3P forms SRPP voltage amplificier. A 6N5P cathode follower is used as driving stage. It can drive headphones from 32 Ohm to 600 Ohm very well. I'm happy with the sound quality when used on my HD600 Here're some of the testing results.
www.siliconray.com High Quality Audio Enclosures, Amp Kits, Amplifiers, PCB Fab Services Chat with me |
#2 |
Hai siliconray,
why using a 6n5 tube when 6n3 can also do a better job in the output stage. The 6n5 is a slow tube with a lot of heatercurrent. If you like the sound oke that is personal. But using 1 tube for both channels is always a compromise. I think it is better to use a 6n3 parallel triode cathode folower in the output like shanling does. And why all that gain? We do all have equipment with 1Vrms or more output voltage. Ronny |
#3 |
6n3 can't drive low impedance headphones well by cathode output. the gain was just Radom set by the volum pot.
#4 |
Try this,
![]() This drives also 8 or 16 ohm headphone with very low distorsion. And it will even sound better with a 6n6p. Also this tube is very cheap. Ronny Last edited by Koifarm; 26th February 2012 at 02:45 PM. |
#5 |
Hi Koifarm
Thanks for posting the schematic, I will try it later. I found 6N5P can even drive speaker very well, I'm sure the power is more than 2W, amazing. BTW, do you think a NFB to the input state will improve the performance? Have a look at our work in a long version RE1506 enclosure
#6 |
Tested with 7723A just now. The distortion is 0.54%, 1KHz, 470 Ohm load, 1Vp-p. Is it good enough for a tube headphone amplifier? My JLH is only 0.008%.
#7 |
What is your +B?
"To err is human.. to make a real balls-up requires a computer" |
#8 |
120V for 6N5P, 150V for 6N3
#9 |
Try to use 200mv input, your gain is to much.
Output power is 90mW you need only 20mW. Or change inputvoltage devider. Last edited by Koifarm; 27th February 2012 at 01:08 PM. |
#10 |
I think the distortion shouldn't be that much even at 90mW. The THD is 0.3% when lower the voltage down to 0.5V.
The 6N5P is a junk tube. Some said this circuit has amazing performance when replace 6N5P with Raython 6080. I will try it tomorrow.
| 6N16 12x preamp srpp/cathode follower with printed circuit board design. | Koifarm | Tubes / Valves | 51 | 3rd May 2013 12:16 PM |
| Cathode follower & SRPP q | Cobra2 | Tubes / Valves | 4 | 22nd February 2008 01:15 PM |
| Schematic please? SRPP with current source cathode follower | riotubes | Tubes / Valves | 0 | 7th January 2007 05:18 PM |
| Question about direct coupling a anode follower into a cathode follower. | G | Tubes / Valves | 45 | 29th July 2004 06:47 PM |
| srpp or m-follower? | GAK | Tubes / Valves | 28 | 3rd September 2003 06:44 PM |
