5k plate to plate, el34 triode strapped, 400v b+
Old 26th February 2012, 01:26 PM   #1
blue andry is offline blue andry  Indonesia
Default 5k plate to plate, el34 triode strapped, 400v b+
one of my el34 got burnt after 6 month of service. I was putting it on an amp that was belong to 6550 Only by minor mod on bias voltage. I always notice the sound of over dissipated plate every time i turned off the amp after listening session. I read on claus brinth 30w pp article that 5k A-A was to tough for el34 triode mode. What would be a better option for me to run el34
1. Lowering the b+ voltage , or
2. Replace iron with higher plate to plate resistances
If opt 1 chosen , please recommend me safe b+ voltage into 5k a-a,
If opt 2 chosen , please share nominal a-a which sounds the best with el34 triode strapped based on your experience.
Thx and regards,
Andry
Old 26th February 2012, 01:29 PM   #2
rntlee is offline rntlee
Here's a chart from Mullard:
Old 26th February 2012, 01:40 PM   #3
artosalo is offline artosalo  Finland
artosalo's Avatar
How much was the idle current/tube ?
Old 26th February 2012, 01:43 PM   #4
Iddle current is 35 mA per tube,
Thanks rntlee for mullard chart,
I'm thinking of 8k, but mullard suggest 10k,
Is there someone with listening impression could share their experince,
Thx,
Andry
Old 26th February 2012, 01:57 PM   #5
artosalo's Avatar
The idle power is well below max. rating. I think the tube has been weak from the beginning. (only one damaged ? )
I can not imagine that with such idle power any sort of normal listening can overload the tube that much.
Old 26th February 2012, 02:08 PM   #6
Yes only one been burnt, but i can hear cling cling sound every time i turned off the amp.
so i would be better off with either one option before pluggin new tube.
Old 26th February 2012, 02:46 PM   #7
boywonder is offline boywonder  United States
boywonder's Avatar
I've been running triode strapped PP EL-34's at 400V/60ma into 5K ohms for a couple of years without issues. 400V x 60ma =24W, right at the dissipation limit.
Your 35ma bias current at 400V is way under the limit for these tubes.
Old 26th February 2012, 05:10 PM   #8
Hi boywonder,
It's nice to hear from u again.
if your amplifier do stable with this operating condition,
Then mine surely had something wrong.
I was very confused of crackling sound every time i turn off the amp.
Is it normal? do grid leak resistor 100k for 6550 should be replace with usual 220k for el34?
Old 26th February 2012, 06:02 PM   #9
the_manta is offline the_manta  Germany
the_manta's Avatar
The crackling sound comes from different expansion coefficients of metal, mica and glass. When the tube is powered on or off there are some slight sudden movements which produce this sound. Tubes with self supporting system like that 211 or 845 without the mica on top wont produce that sound becausse they're clamped to the bulb only at the bottom and can expand in the top direction.
Nothing to worry about.
When you turn your car engine you hear a similar sound.
Aluminum heads on a cast iron engine block work well. So do iron anodes in glass tube.
Терпенье и труд все перетрут
Old 26th February 2012, 07:11 PM   #10
boywonder's Avatar
Are you running cathode bias or fixed bias? Sounds like either of those grid leak numbers are reasonable; my amp has 150K grid leaks, and it's fixed bias (Poindexter's 6GK5/EL34 MM).
5k plate to plate, el34 triode strapped, 400v b+Hide this!Advertise here!
how to connect an EL34 pentode into a triode and 100ohm resistor between plate and g2 jarthel Tubes / Valves 15 26th October 2013 03:44 PM
EL34 plate glowing? ultrachrome Tubes / Valves 15 1st June 2011 04:55 PM
EL84 PP using 5K plate to plate primate OPT jmillerdoc Tubes / Valves 5 9th March 2010 10:14 PM
Recommended primary output impedance for triode strapped EL34? G Tubes / Valves 12 10th August 2005 10:32 PM
Copyright ©1999-2017 diyAudio
