I've constructed a simple 2-stage valve preamp (voltage gain and cathode follower).
Each of the stage works fine independently, but once i put the stages together with a capacitor the cathode follower's bias voltage changes and puts it in cut-off state. Im suspecting that its caused by the coupling capacitor's leakage but i can't be sure, I'm currently using a 250V Metalized P.E. cap. If it is caused by the leakage, then how do i solve it, if not then what other causes could there be? |
#2 |
A schematic would help. If you have photos, that would also be nice (it COULD be as simple as a wiring error).
If there's a sucker born every minute, where do the rest of them come from? |
#3 |
Coupling capacitor leakage almost always turns the next valve on too hard, not off. My guess is that you have a circuit or wiring fault. A diagram would help.
| Capacitor Leakage current | nonoise | Parts | 3 | 17th January 2011 08:42 AM |
| Black Gate capacitor reforming and leakage | AndrewT | Solid State | 12 | 5th July 2010 07:43 AM |
| Transformer or capacitor coupling? | neazoi | Tubes / Valves | 13 | 26th June 2010 05:36 PM |
| Pearl: Coupling capacitor | h_a | Pass Labs | 5 | 10th January 2007 05:51 PM |
| Need 33uF coupling capacitor | eehobby | Parts | 2 | 3rd September 2003 02:53 AM |
