Old 9th October 2012, 04:15 PM   #181
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Its the spice JFET models don't care maybe. I have read many times they are not the most elaborate in conception VS BJT models for instance. Thanks for the welcome, I wish I knew how to repair a TV myself. Me just a simple audio circuits hobbyist, messing up all the time.
Old 9th October 2012, 04:29 PM   #182
popilin is offline popilin  Argentina
popilin's Avatar
You are very humble, typical of those who truly know.
Just seeing your designs can be seen clearly.
BTW, I am designing a 650 V PSU, I hope you don't mind if yours inspire me.
I do not suffer from insanity, I enjoy every minute of it. -Edgar Allan Poe
I'm not crazy about reality, but it's still the only place to get a decent meal. -Groucho Marx
Old 9th October 2012, 05:16 PM   #183
Salas's Avatar
Maybe a J309 for cascode's top? How that fairs in your sim?
Old 9th October 2012, 06:20 PM   #184
popilin's Avatar
Thanks for your advice.
According to the datasheet, the J309 looks good, I must only find the mathematical model.
I must confess that I hate Fairchild's bureaucracy whenever I seek any model.
As I have, I will publish the results.
Old 9th October 2012, 07:45 PM   #185
Salas's Avatar
.model J109 NJF(Beta=12.42m Betatce=-.5 Rd=1 Rs=1 Lambda=35m Vto=-3.002
+ Vtotc=-2.5m Is=533.7f Isr=5.174p N=1 Nr=2 Xti=3 Alpha=152.8u
+ Vk=111.9 Cgd=47.7p M=.4283 Pb=1 Fc=.5 Cgs=47.7p Kf=169.9E-18
+ Af=1)
Old 9th October 2012, 09:55 PM   #186
popilin's Avatar
Hi Salas
I found a model from Philips, thanks a lot, I will try your model soon.
J309 is a very clever choice, distortion remains the same because of +B, but now, noise is lower.
Old 9th October 2012, 10:07 PM   #187
Salas's Avatar
ECC802S 12AU7 ECC82 heater question korabetsni Tubes / Valves 8 3rd July 2012 12:03 PM
12au7 ecc82 nigelwright7557 Parts 0 29th March 2010 01:07 PM
FS: single nos telefunken ECC82 (12au7) PreSapian Swap Meet 0 4th January 2010 03:03 AM
Do I need a Trafo for the HV in my 12AU7 (ECC82)? DaMeat Tubes / Valves 13 10th August 2007 10:08 AM
line preamp using 6SN7 instead of 12AU7 JPS Tubes / Valves 11 23rd May 2007 12:05 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
