input transformer and impedance question - diyAudio
Old 25th February 2012, 02:28 PM   #1
Default input transformer and impedance question
Hi guys
I am wondering how to use the 600:600 for eg. Jensen 11ssp8ma and 10k:10k 11p1 Jensen transformer
How do I determine which is high or low impedance circuit?
For eg. The input of #26 single ended preamp. Are they low or high impedance circuit?
Thanks in adv
Erwin
Old 25th February 2012, 04:56 PM   #2
SY's Avatar
For nearly any home audio application, high input impedance/low output impedance is standard. For an input transformer for a normal tube preamp, the JT-11P1 is an excellent choice. The loading on the secondary is critical, though- you'll want to follow the Jensen app note suggestions. A series RC network across the secondary will often clean up a bit of ringing that Miller capacitance can cause.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 25th February 2012, 05:03 PM   #3
Hi SY
Thanks for your confirmation. I got it now
Any other suggestion of input transformer beside the Jensen JT-11P1?
Hence I assume 600:600 is not a good choise for the #26 preamp input?
Where does 600:600 transformer best suited location?
Erwin
Old 25th February 2012, 07:12 PM   #4
Miles Prower's Avatar
Originally Posted by milen007 View Post
Hi guys
Thanks in adv
Erwin
This is a question that comes up all the time. If you consider the theory of mutual inductance, what you find is that under conditions of loose coupling that what you hang on the secondary has little effect on what happens at the primary, since the jwM is so small.
Even if the coupling is tight, the same applies if the secondary load is much larger than jwM, and it will likewise have little effect since the current is quite low, even if the voltage is large due to a bigger jwM term.
In either case, a 600 : 600, or a 10K : 10K interstage, you have a 1 : 1 voltage ratio, and the xfmr is acting simply as a buffer, usually in order to break up a ground loop by means of electromagnetic isolation.
What the impedances do tell you is what sort of frequency behaviour you can expect. A 600 : 600 will have less inductance, and will have poorer low frequency response if connected to higher than a 600R load. For broadband xfmrs, the Xl of the primary should be ~4 -- 5 times the resistance connected to it. At the very least, Xl should be equal to Ri; more would be better, but it's a good deal more difficult to make Xl= Ri at 20Hz than it is at 2.0MHz. RF xfmrs are a good deal easier to make than AF xfmrs.
"The input of #26 single ended preamp. Are they low or high impedance circuit?"
If connected grounded cathode, it's a very high impedance load. If connected grounded grid, a much lower impedance load. If connected GK, then the xfmr you choose will be determined by the source impedance. If connected to a Lo-Z source, you'd prefer the 600R xfmr. If it's a Hi-Z source, then you'll get better performance from the 10K IST.
There are no foxes in atheistholes
www.dolphin-hsl.com
Old 25th February 2012, 08:25 PM   #5
SY's Avatar
What Miles said.
A nice alternative to the Jensen is Cinemag CMLI 15-15. It seems to be every bit as good as the Jensen, but cheaper. Sowter's 3575 looks very nice, but I haven't tried it myself.
Old 26th February 2012, 02:08 AM   #6
Hi guys
Please pardon my ignorant. What's "jwM" and "connected GK' means in Miles post. Thanks
Erwin
Old 26th February 2012, 03:04 AM   #7
Hi guys
Erwin
j= sqrt(-1)
w= 2 X pi X f (radians/sec) angular frequency
M: Mutual inductance
M= k X sqrt(Lpri X Lsec) (k: coupling coefficient)
GK: Grounded Cathode
www.dolphin-hsl.com
Old 12th November 2014, 09:04 AM   #8
Bumping up old thread so i don't clutter this forum with new one.
See the attached (input/interstage?) transformer from UTC that i have. I want to use it as input transformer. It's for a push-pull bass guitar amplifier so it doesn't have to be hifi. Seeing that it's already center-tapped, can i use this as input+splitting transformer which goes to a pair 12AX7 having 1M grid resistors? i.e from the bass pickup coil, signal goes to the 100R input and 600R output goes to 12AX7.
In this case, i believe the load is approximately 1M (12AX7 grid resistor) so i guess i will lose low frequencies?
Old 12th November 2014, 09:19 AM   #9
I think i get it..
600R impedance have lower inductance than 10K (simply because it has less winding) so when connected to 1M resistor, i will lose low frequencies because i'm making shunt LR network having low L inductance.. so at low frequencies, the L part is like a short circuit to ground (no signal going to tube grid). Did i get it right?
Old 12th November 2014, 12:32 PM   #10
Wait.. my conclusion doesn't sound right.
Low-z output (600R) coupled to High-Z input (1M) is favorable, isn't it?
So, the problem is how to drive the low impedance primary (100R).
That 12AX7 will be Grounded Cathode so it's only a matter of my 100R primary driver, right?
question on very high input impedance for B1 wintermute Pass Labs 8 3rd April 2010 02:20 PM
input impedance of mosfet question? AudioGeek Solid State 2 9th November 2009 04:11 AM
Chipamp input impedance question EBM_dude Chip Amps 6 26th October 2009 05:52 PM
Amp input impedance question ? sam9 Solid State 9 21st April 2005 03:28 PM
P3A question: high input impedance sobazz Solid State 1 14th July 2003 06:45 AM
Copyright 1999-2017 diyAudio
