Options for 300mA tube rectifiers
Old 25th February 2012, 11:41 AM   #1
andyjevans is offline andyjevans  United Kingdom
Default Options for 300mA tube rectifiers
It's always tricky to find tube rectifiers capable of 300mA at 350v to 400v for things like Push Pull amps.
I've had good results so far with two 6BY5, and about to try two 5R4GY. I've previously used damper diodes like 6DT4, but a pair are problematic around 250ma and over.
What are your solutions and experiences?
Andy
Old 25th February 2012, 12:23 PM   #2
Eli Duttman is offline Eli Duttman  United States
A GZ37 is good for 350 mA., into a choke I/P filter. Only 275 mA. are available from a GZ37, when cap. I/P filtration is employed.
Eli D.
Old 25th February 2012, 02:23 PM   #3
Vinylsavor is offline Vinylsavor  Germany
Vinylsavor's Avatar
Hi Andy,
many choices among the TV dampers. Since each diode will only conduct half the time, the current drawn from a pair or a bridge can be twice the DC current capability of a single diode. I'd leave some margin however. A 6AU4 might just be enough.
300mA will be absolutely no problem for 6CJ3, EY500 or 6CG3:
VinylSavor: Tube of the Month: The 6CG3
Best regards
Thomas
http://vinylsavor.blogspot.com/
Old 25th February 2012, 03:06 PM   #4
roline is offline roline  United States
roline's Avatar
I use solid state bridges with a 6CG3 as a "pass device" in the B+ to delay conduction to the rest of the amp to match the tubes as they warm up. First application was on the KEG-EAR ST70 clone application, worked great so I'm using it in all other power supplies.
SO many tubes, SO little time!!!
Old 25th February 2012, 03:11 PM   #5
radiostar is offline radiostar  Yugoslavia
PY500A is also very good for excellent price, if you can afford new transformer for heating ...
tubes.rs
Old 25th February 2012, 03:18 PM   #6
Palustris is offline Palustris  United States
Palustris's Avatar
The 5V3 and 5V3A should handle the current without a problem.
Old 25th February 2012, 08:24 PM   #7
I think a pair of 6AU4GTAs will be quite adequate in a 300 mA. PSU. A look at the data sheet shows a 190 mA. DC rating as a (sic) 1/2 wave rectifier. Damper diodes are built to take repeated large pulse draws. A "yank" 50 or 60 times a second rates to be a "piece of cake". The only thing to watch out for is an excessive turn on surge working into a cap. I/P filter. Don't be aggressive in sizing the 1st filter cap. and (of course) use a CLC filter.
Eli D.
Options for 300mA tube rectifiersHide this!Advertise here!
Tube rectifiers razorrick1293 Tubes / Valves 15 14th September 2014 02:42 AM
Tube Rectifiers do sound different Burnedfingers Tubes / Valves 122 27th April 2012 07:43 PM
Small (Novel) Tube Rectifiers? Kashmire Tubes / Valves 29 7th May 2010 04:27 AM
Tube rectifiers for Dummies bigjppop Tubes / Valves 8 17th July 2009 07:04 AM
Tube rectifiers NickC Tubes / Valves 32 7th November 2002 10:10 PM
Copyright ©1999-2017 diyAudio
