I would like to build a pre-amp. It would be my first build.
Looking on this site, I found this preamp build and looked like a good candidate. 12b4, 6ca4 build questions.... - AudioKarma.org Home Audio Stereo Discussion Forums Looking through my parts supply, I found a choke and it has 3 leads, it was used in a power supply circuit. All the references I come upon, the chokes have just 2 leads, can anyone explain the use of the 3rd lead. Feel free to comment on my choice of the 12b4 preamp as my first build. Here is the schematic of that circuit -Brad
#2 |
This is your first build. I am by no means qualified, and am still looking at trying a first build, but this would scare the crap out me. There has got to be something more less intense than this.
#3 |
The schematic shown is not of the build, it is of the a tube receiver in which the choke came out of. I'm trying to learn how this choke with 3 leads differs than all the other chokes I see that only have 2 leads and if I can utilize it in my preamp.
#4 |
If it really is a center tap then you can either have a 7.5H or a 3.75H choke depending on how you connect it.
#5 |
No, a centre tap would give you a quarter of the total, not half. Inductance varies as turns squared.
#6 |
#7 |
That circuit is doing something more complicated, but I can't quite work out what. Maybe some form of hum cancellation?
| Question on choke | BHD | Tubes / Valves | 2 | 11th June 2009 03:45 PM |
| Choke question | JoshK | Tubes / Valves | 5 | 1st December 2008 03:31 PM |
| Choke question | nkg | Tubes / Valves | 26 | 22nd November 2006 08:39 PM |
| Newbie needs help. Basic PSU design and choke question. | RockysDad | Tubes / Valves | 8 | 18th February 2004 05:37 AM |
| newbie post, but hopefully not a newbie question | wiredcur | Solid State | 3 | 24th August 2002 10:49 PM |
