Old 24th February 2012, 06:07 AM   #1
sunbeam is offline sunbeam  New Zealand
Default ECL82 amplifier help
HI Folks, I've just aquired an old 60's stereogram and i'm thinking of re-purposing it as a small stand alone amp, just for a bit of fun. The existing layout is an ECC82 as preamp, EZ81 rectifier and an ECL82 per channel as the output stage.
What I would like your learned opinion on is weather it would be better to recreate the existing circuit less RF stage/tone controls etc or would it be best to start afresh reuseing as many of the old bits as possible. Any help wuld be greatly appreciated!
Old 24th February 2012, 06:48 AM   #2
aardvarkash10's Avatar
if you are using a CD, Iphad or computer as a source, you won't need the ecc82.
I'd also go ss rectification so you can go large on power supply caps for smoothing.
By then, you are repurposing I guess
"Folks, you can't prove truthiness with information. You prove truthiness with more truthiness. In a process known as truthinessiness." - Stephen Colbert, The Colbert Report
Old 25th February 2012, 02:23 PM   #3
I prefer tube rectification, for me it plays better than ss ...
tubes.rs
facebook.com/tubes.rs
Old 25th February 2012, 08:00 PM   #4
True, when crappy 1N4007 diodes are used. If high PIV Schottky diodes are used, no switching noise is generated. Some restraint in sizing the 1st cap. of the PSU filter remains necessary. Neither the power trafo overheating nor the "hash" associated with very short charging pulses (tiny conduction angle) is desirable.
Eli D.
beginner's ecl82 skyraider Tubes / Valves 30 18th October 2011 02:46 PM
Mullard ECL82 6BM8 john65b Swap Meet 3 24th August 2010 02:35 AM
ecl82 or ecl86 amplifier decision neazoi Tubes / Valves 10 17th July 2010 05:54 PM
Ecl82 alexandar888 Tubes / Valves 15 10th May 2009 07:39 AM
6bm8/ECL82 vs EL84 akimball442 Tubes / Valves 15 26th January 2009 01:34 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
