Designing a Gomes i/v stage for tda1541a
Old 28th February 2012, 03:28 PM   #21
revintage is offline revintage
It´s no problem to add the DN2540-model.
Old 28th February 2012, 04:14 PM   #22
ThorstenL is offline ThorstenL  Germany
Previously: Kuei Yang Wang
Originally Posted by studiostevus View Post
I did some more simulations, and got THD down to 0.000543%.
Don't overdo it on cancellation. It sounds worse and becomes extremely sensitive to tube variation.
-removed the Rk bypass cap. Of course I lose gain, but I dont really need it... what else do I lose by removing the cap? Slew rate?
Unbypassed resistors add noise. That is one of the reasons neither CD-77/777 or DP-777 have very low noise.
-voltage divider between the left triodes. I can't really rationalize why this is beneficial though, but it simulates better... The top-right triode now gets a out-of-phase signal which is smaller in amplitude.... maybe better match with the bottom-right triode plus its plate resistor?
Gomes always uses signal from lower anode, not upper cathode.
As you know from the CD-77 it uses an ECC81 in the first stage and a 5687 in the second.
So we are clearly doing some more, as Doctor Who likes to call it, "jiggery pokery"...
Ciao T
Old 28th February 2012, 09:57 PM   #23
studiostevus is offline studiostevus  Netherlands
Simulated the CCS with DN2540, both straight and cascoded... don't get to THD specs as with the tube...
Old 29th February 2012, 05:38 AM   #24
You still don´t get it about simulations?
1 The .four is not to trust!
2 THD is uninteresting, harmonic spectra is!
But if you believe Spice is correct, the spectra of the Gomes is not nice as the higher overtones doesn´t diminish the higher they get. How it is IRL I don´t know but probably better.
And as I said to get a better picture you must try many different tubemodels. Why not try what T used in his design, a ECC81.
In a world were the amp with the lowest THD sounded best, it would be easy to choose.
Old 29th February 2012, 06:06 AM   #25
Attached a real Gomes stage, outputting 2V RMS into 10K. Note that this one deliberately did not have any aggressive distortion cancellation applied. Plus the ECC81 is a less linear Valve than the 12AY7.
As we can see, 2nd HD is around 0.3%, 3rd is 0.003%, 4th is MIA, 5th is 0.002% & 6th and higher at 0.0005% or lower. The spike above 10KHz is from the environment, not the test gear, maybe a CRT Monitor leaking in.
We can cancel the 2nd HD a lot more, but 3rd and 5th are then higher and the HD becomes more tube sample dependent. And it does not sound as good.
Using 6072A/12AY7 lowers 2nd HD appreciably, as it is basically a linearised and "audio grade" ECC81. Other ECC81 analogs, such as 5965 also give lower 2nd HD.
Ciao T
Old 29th February 2012, 06:10 AM   #26
Thanks Thorsten,
As I suspected. Not at all as a simmed FFT of a Gomes.
Old 29th February 2012, 06:30 AM   #27
Originally Posted by the_manta View Post
I hope you know John Broskie's issue about the gomes configuration: Gomez Vs XPP Amplifier
I hope you know that much of what John does is theoretcal/simulated only, that he massively overemphasises PSRR over any other considerations and rarely if references what he does to evidence of what is audible?
I had twice the occasion of rescuing projects a friend and DIY Kit Vendor had based on stuff posted at that site which simply did not work properly... I ended up completely redesigning the projects as the original circuits neither worked well electrically in reality nor sounded any good...
So any of his blog posts should be taken "cum grano salis magnitudinem montis".
Ciao T
Old 29th February 2012, 07:25 AM   #28
Thanks Thorsten,
I must add, there is a TDA1541 DAC included in this plot, running "sans un filtre numérique", so it is likely to add to some of the higher order stuff.
Here by comparison a TDA1541 with Op-Amp (LM6181 current feedback) analog stage:
This is probably about as as it gets for the TDA1541.
Ciao T
Old 29th February 2012, 07:45 AM   #29
Makes you wonder why we mess around with tubes
Thorsten, what's your view on using a Mosfet CCS to replace the top left triode as suggested earlier?
Also i will change the operating point. Not comfortable to work with 400v in a Dac... Should be possible to get good results with lower voltage, also on 6072a.
TDA1541a-S2 / 6072a / MediaplayerDac -- Michell Gyrodec -- Aikido Preamp -- Pass F5 -- Audio Physic Tempo 2SE -- Yamamura Cabling
Old 29th February 2012, 07:47 AM   #30
Hey T,
It´s in the opposite direction. Your sim looks better in the higher order area than the sim. Just by looking at the fourier-analysis you can tell there is something funny going on.
Can also agree about the blogs. This also goes for the .four-sims above.
Designing a Gomes i/v stage for tda1541aHide this!Advertise here!
a JFET Preamp with Gomes XPP Stee Solid State 0 10th August 2009 09:24 AM
Gomes amp revintage Tubes / Valves 9 9th July 2007 09:51 AM
Another I/V stage for TDA1541A Sandor Digital Source 1 6th December 2006 07:09 AM
Designing an Output stage for an LM402 dfdye Solid State 7 22nd May 2006 08:13 AM
Designing a phono stage Brownlow Solid State 15 3rd May 2001 02:21 PM
