Designing a Gomes i/v stage for tda1541a - Page 5 - diyAudio
Old 1st March 2012, 05:47 PM   #41
Or this hybrid gomes... THD (simulated) with cancellation between tubes (which is difficult to achieve in real life).... 0.0009%
Old 2nd March 2012, 03:20 AM   #42
Previously: Kuei Yang Wang
Originally Posted by studiostevus View Post
This is the alternative mu follower I have doctored... THD of 0.22%... no cancellation between tubes, lower B+.... biased with the TDA1541 offset
I am not convinced.... Thorsten, you have surely tried both mu follower and gomes topologies, and have advocated the gomes typology several times on this forum. Which one to pursue?
You need to pursue whichever fits your requirements.
The Gomes Stage set up correctly gives comparably low distortion, low noise and low output impedance without recourse to negative feedback.
Other circuits may produce better measured performance in one aspect or another or better subjective performance. It also depends on the Tubes you decide to use and the application.
You know what I have implemented for commercial products and it includes Hybrid Mu-Followers (diyhifisupply Universal Tube Stage), Gainstage/CCS Loaded Cathode follower (AMR CD-777), Gomes Stage (AMR CD-77 and 3D Sonics Shanling Modifications) and Super-Mu-Follower (AMR PH-77) and plain resistive loaded common cathode stages (AMR AM-77/AM-777), heck I have even used solid state and (Gasp, Shock, Horror) generic Op-Amp's for some OEM Designs.
Ciao T
Old 24th June 2012, 08:10 PM   #43
So I finally got around to building this. I have decided to do the grounded cathode version, with fixed bias from the TDA1541a. It sounds pretty great, even in a proto setup (final setup will be dual mono psu and salas HV shunt), better than my discrete I/V powered by Salas LV shunts.
Still need to tweak it a little bit, I didn't have the correct resistors to choose the optimal biasing point. What are other ways of further improvements? How to go about distortion cancellation?
Behold the plot (didnt manage to calibrate ARTA properly, so it looks better than it is)...
Old 9th September 2012, 05:26 PM   #44
Today I tried to improve the operating point of the Gomes stage to a more linear area of the 6072a tube. Strangely, it measures worse.... Where do I go wrong in my thinking?
Old setup:
I/V = 33R, so fixed bias is 6.6mV (based on -2mA idle current from tda1541a)
Rk = Rak = 51R
New setup:
Rk = Rak = 18R
Based on the datasheet I expected distortion/harmonics to improve....
http://www.mif.pg.gda.pl/homepages/f...093/6/6072.pdf
TDA1541a-S2 / 6072a / MediaplayerDac -- Michell Gyrodec -- Aikido Preamp -- Pass F5 -- Audio Physic Tempo 2SE -- Yamamura Cabling
Old 14th September 2012, 09:14 PM   #45
nobody?
Old 1st February 2013, 06:47 PM   #46
so did you end up using the very first circuit you posted?
im looking for a suitable 1541 output atm.
Old 4th February 2013, 12:15 PM   #47
Yes, works well
a JFET Preamp with Gomes XPP Stee Solid State 0 10th August 2009 09:24 AM
Gomes amp revintage Tubes / Valves 9 9th July 2007 09:51 AM
Another I/V stage for TDA1541A Sandor Digital Source 1 6th December 2006 07:09 AM
Designing an Output stage for an LM402 dfdye Solid State 7 22nd May 2006 08:13 AM
Designing a phono stage Brownlow Solid State 15 3rd May 2001 02:21 PM
Copyright ©1999-2017 diyAudio
