#21 |
"Semis" work only and only when the amp starts clipping while output is disconnected, otherwise they are out of signal path. However, you need quite powerful and fast high voltage diodes. I used diodes that I salvaged from TV sets.
If I disappear suddenly, that means I finally created a time machine and pushed wrong button that brought me to Stalin's Russia. In any experiment any result is the result. Even if it is negative. |
| Electrical Saftey and a ground loop | ccdoggy | Parts | 7 | 21st January 2008 06:43 AM |
| Wanted: DIY amplifier builder with experience. I need a 0.7 ohm stable amplifier | Audiophilenoob | Swap Meet | 34 | 16th May 2005 11:58 PM |
| Soldering Saftey | RobPhill33 | Equipment & Tools | 41 | 6th August 2004 10:26 AM |
| Questions about how to decrease the PASS A-40 amplifier into a class AB amplifier. | novtango | Pass Labs | 2 | 21st October 2002 01:50 AM |
