6n18p 6n1p 6n2p project needed - diyAudio
Old 21st February 2012, 05:59 PM   #1
Default 6n18p 6n1p 6n2p project needed
first post so hello everybody
i've recently had enough of reaping on valve theory so i am looking to learn by applying. i've ordered a load of valves from russia 6p18p, 6n2p and 6n1p, i was hoping some body could sueggest a good project for me to start with. not really bothered whether it is guitar or audio.
Old 21st February 2012, 06:10 PM   #2
kevinkr's Avatar
Welcome to the forum akadazzle!
You might want to think a little about what you would like to do - if you go in the direction of guitar projects then I can move this thread to Instruments & Amplifiers..
You haven't mentioned anything about your skill level so you might want to start there, and I would certainly also recommend reading the newbies and high voltage safety threads before doing anything.
I believe the tubes you have purchased are probably most suitable for things like guitar pre-amps and phono stages due to medium to high mu of the types purchased. Not the easiest point of entry in either case, but manageable with care and patience.
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 21st February 2012, 07:01 PM   #3
thank you for the welcome Kevinkr.
it might be a gd idea to move this thread actually, sorry for the trouble =)
as for my skills, i have a lot of understanding of desinging with silicon based effects, amps, etc, and i understand a lot of valve theory (including dangers), but i struggle to apply that theory as i think i just read too much with nothing in front of me to mess about with.
i was thinking the 6n1p would be good for line level amps in audio mixers? i agree about the other two though, that's why i originally bought them, fancied my hand at a guitar SE 5W-ish but couldn't find anything for el82/6p18p
i was wondering if anyone has any experience with these valves, in audio or guitar and could let me know how they sound?
thanks in advance everyone
Last edited by akadazzle; 21st February 2012 at 07:12 PM. Reason: accidently posted before finishing
Old 21st February 2012, 08:43 PM   #4
Bone is offline Bone  United Kingdom
Hi akadazzle, this guy used a EL82/6p18p to build a Champ clone. 5wattamp He used a ECC82 as well, but you could use a 6n2p which is similar to the ECC83/12AX7 which is what the champ originally used. The output transformer should have the same Primary impedance as the Champ transformer eg 4.5k to 6k or so. RS components do an output transformer 210-6475 which will give you about 3watts. (order on line - free delivery)
Old 21st February 2012, 09:59 PM   #5
the_manta's Avatar
welcome on board !
Well, when you got all the theory, why would you need a schematic
Even better. Designing with valves is a lot easier than with silicon. There is no current gain or Base current. (As long as you don't go into grid current operation)
The reason why you won't find anything is really very simple. Neither the EL82 nor the 6П18П were much used for audio amplification. Their primary use was vertical sweep in television receivers. There were much better tubes for audio in the 8-range (noval socket) like EL84 and EL86.
Furthermore a 6П18П is not really an EL82. They were just used for the same purpose.
You can't just tell how a tube sounds. Everybody will tell you another story. It depends on so many factors (power supply, output transf., driver stage, feedback, etc.) that it seems kind of funny to hear such a question
I added the 6П18П datasheet in my post. There are even triode curves ! Just use some simple SE amps as guidance and use the specs in the sheet to build what you want.
And to make it easy....when you take a EL84 amplifier as basis, you will just have to adjust your screen voltage and cathode resistor
Терпенье и труд все перетрут
Old 21st February 2012, 10:15 PM   #6
in answer to Manta, "Well, when you got all the theory, why would you need a schematic". i aren't entirely sure i have the theory till i put it into practice. and as for asking how tubes sound, different op amps sound better than others , i assumed the same would be true with tubes.
thank you for the datasheet i've been looking for that for ages, and thanks Bone for the idea, i think i'll defo be trying that out
Old 21st February 2012, 11:19 PM   #7
the_manta's Avatar
OK, now I know what you mean. The thing is, you can just swap an NE5532 for an OPA604 without difficulty. These integrated circuits work on wide operating voltage range and gain is set just by the feedback.
But you can't just swap an ECC82 with ECC83. The operating points won't match as won't the gain and other parameters.
Of course there are debates about the sound of the same tube from different manufacturers.
Old 1st March 2012, 07:17 PM   #8
can any 1 suggest a decent power tx for this (b+250) so far the best i found is for 20w pp from ampmaker.com, it's a bit overkill for my needs really
Old 1st May 2012, 11:15 AM   #9
Dragondreams's Avatar
Just spotted this and thought you might be interested to hear a clip I recorded with an amp I've just finished.
The amp uses a 6N1P feeding a 6N2P feeding a 6N1P into one of Ampmaker's 4Watt PP output transformers.
The lead guitar was recorded from a couple of mics pointed at a 4x12 cab.
http://www.dragondreams.org.uk/twatt/twatttest.mp3
The reverb and echo were added in Reaper.
Experience is what teaches us to make a different mistake next time...
Old 14th October 2012, 01:29 AM   #10
thanks for the info guys =)
decided to try things with an el84 first then mod when i happy with pre amp, just had a couple of solid state amps come my way and had to take a lot of time of the valves because of it.
in my time between different repairs i have come up with this, feel free to criticise, and plz ignore the mistake what makes the 220k load look like a pot
1.2W guitar amp useing:6N2P and 6N1P russian tubes. AnalogSound Instruments and Amps 2 21st May 2013 06:50 AM
Newby project idea for HND main project help and advice needed please WIGANWEZ Chip Amps 1 17th September 2011 05:59 PM
Newby project idea for HND main project help and advice needed please WIGANWEZ Chip Amps 0 17th September 2011 02:39 PM
miniatures 6n1p 6n2p v4lve lover Tubes / Valves 8 19th February 2011 09:27 PM
RUssian 6P14P-EV / 6n23p / 6n2p-ev / 6n8s / 6n1p / etc+ UssrTradeCom Vendor's Bazaar 0 2nd August 2010 10:39 AM
Copyright 1999-2017 diyAudio
