diyAudio Sponsor
Old 24th September 2003, 08:05 PM   #1
G is offline G  United States
G's Avatar
Default Crucial to match tubes when running PSE?
Hi All,
If I wanted to build a amplifier with a PSE output stage would I have to use "matched" tubes? What are the consequences if I don't? Thanks.
G
Gavin
Old 24th September 2003, 09:11 PM   #2
diyAudio Senior Member
fdegrove's Avatar
What's the bias arrangement you're using?
Frank
Old 25th September 2003, 02:57 AM   #3
G's Avatar
Hi Frank,
I would be using one pair of tubes per side with one cathode resistor for each pair of tubes.
G
Gavin
Old 25th September 2003, 11:25 AM   #4
fdegrove's Avatar
Hi Gavin,
As long as the output tubes aren't grossly mismatched the common cathode bias resistor will tend to equalise the current between the pair.
If possible I'd still try not to mismatch the output tubes for some current hogging will still occur making the tubes ages unequally.
Frank
Old 25th September 2003, 12:28 PM   #5
dhaen is offline dhaen  Europe
diyAudio Moderator Emeritus
dhaen's Avatar
Default Sorry, I have to disagree
Frank,
I've been looking at your last post for a while, wondering what's going on.
With parallelled valves, the greedier valve will starve the lesser one of current, because it sets the cathode voltage, and hence the grid bias conditions.
I think there are less problems in push-pull, but this is PSE.
Old 25th September 2003, 12:34 PM   #6
fdegrove's Avatar
Default Re:Sorry, I have to disagree
Hi John,
Thing is, I DO agree with you which is why I advised against mismatched tubes.
Maybe I should have stated that more clearly...
Frank
Old 25th September 2003, 12:42 PM   #7
dhaen's Avatar
Default We agree
Well Frank, what do you think of the suggestion that Gavin uses individual cathode resistors?
I believe it should be sympathetic to a greater valve mis-match than with a single resistor.
Old 25th September 2003, 01:03 PM   #8
fdegrove's Avatar
And make a part of the individual resistors adjustable?
Frank
Old 25th September 2003, 01:22 PM   #9
dhaen's Avatar
Now you're taking the
Still, it is the best in the world (and not probably)
For G:
It is possible to get a match between 2 not-too-dissimilar devices by matching their curves at 2 points. To do this, you have to tweak the bias point for one end, and the drive for the other. It's a lot of ********, and you're best to find valves that are a reasonable match.
If you have a TV with a CRT, this is how the 3 electron guns are matched.
Old 25th September 2003, 01:23 PM   #10
Colt45 is offline Colt45  Serbia
Send a message via ICQ to Colt45
yeah, a seperate Rk for each lamp should have better current sharing. with a common Rk, the greedier tube can be greedier.
Why match tubes? oldmanStrat Tubes / Valves 8 29th May 2009 02:57 AM
Running different tubes fauxpas Tubes / Valves 2 19th December 2007 12:25 PM
How to match tubes? pftrvlr Tubes / Valves 2 12th August 2007 08:59 PM
Running tubes at lower voltages Redemption Tubes / Valves 23 4th January 2006 02:45 PM
Page generated in 0.10877 seconds (81.43% PHP - 18.57% MySQL) with 11 queries
