Caddock MK-132 or Mills MRA-12 as plate R? - diyAudio
Old 19th February 2012, 09:13 AM   #1
metako is offline metako  Australia
Default Caddock MK-132 or Mills MRA-12 as plate R?
The Caddocks are smaller and cheaper than the Mills (both 100K/400V) but are they suitable as plate resistors in a guitar amp? I'm looking for the quietest resistor to help quieten a noisey amp.
Old 20th February 2012, 09:02 AM   #2
To put the question another way: are the Caddock film type of resistor as quiet as the Mills wirewounds, or do wirewounds rule for quietness?
Old 20th February 2012, 09:45 AM   #3
The Millls are very good for noise and somewhat more tolerant of overloads.
Old 20th February 2012, 10:17 AM   #4
euro21 is offline euro21  Hungary
MK-132 as plate resistor?
Max. dissipation only 0.75W!
Old 20th February 2012, 10:43 AM   #5
Well I've read of guitar amp modifiers commonly using 0.5W as plate resistors so I thought the important figure was the voltage rating. But obviously this is wrong. I'll go with the Mills. Thanks to you both for your input.
Mills MRA-5 resistors in tube circuits dodo Tubes / Valves 1 23rd April 2010 01:15 AM
Caddock MP 132 Rob11966 Parts 0 2nd March 2009 10:05 AM
Holco/PRP or Caddock MK-132 Resistors? caesar148 Solid State 2 5th December 2007 05:05 PM
Replacing Emitter (metal plate cement type) with Mills WW non-ind.-Any Improvement? dtm1962 Solid State 2 29th August 2006 06:12 AM
Mills MRA-5 Svetlana Pass Labs 4 2nd July 2004 02:55 AM
Copyright 1999-2017 diyAudio
