Potentiometer Desigations/Codes - diyAudio
Old 19th February 2012, 08:02 AM   #1
NZkeith is offline NZkeith  New Zealand
Send a message via Skype™ to NZkeith
Default Potentiometer Desigations/Codes
Hello there Folks.... Greetings from New Zealand..... I just wonder IF there is ANYONE out there that can clear this on up, once and for all !!!!!!!
I have been using "TONE STACK" software from "DUNCANAMPS", really a wonderful download to use.... BUT I am as confused as the rest out there and a GOOGLE search just seemed to comfirm the confusion....
In their software... When using, let's say the 'JAMES' tonestack simulator,... one has the choice of different 'Pots' .... Linear, Log A and Log B ..... The default is Log B.....
OK, now I know 'Linear' as 50% resistance at 50% mechanical rotation and 'Log' is normally about 10% resistance at 50% mechanical rotation.... So far so good !!!!!!
NOW.... What is with this "LOG A and B ". There seems to be as many answers as those that ask the question ???? Just to add to the confusion.... There is a USA designation, a European designation and then on top of that all... OLD and NEW codes/desinations. Some say that A is for Audio and B is for Linear ?????? Others exactly the opposite ?????
Wonderful to play around with this great piece software, just need some clarity and as far as I can see, I am not alone....
Many thanks for a great forum, just so many that are willing help... very much appreciated.....
Keep well, best to all....
Keith
When changing the 'type' of pot, the results are ALL different, 'linear' is not either A nor B ??????
Old 19th February 2012, 08:17 AM   #2
You have positive-log and negative-log pots often called anti-log.
Here´s a link to log-lin-antilog curves and how to customize a log pot.
http://www.elby-designs.com/document...ionometers.pdf
Old 19th February 2012, 04:57 PM   #3
Hello there ALL. thanks a stack for the reply, just a little clearer, .... So now I just have to find out just what the 'off the shelf' pots are at the retailer...... I am still confused.... Some say 'Log A' is for 'Audio' taper..... But by your suggestion 'log A' could be 'Log Anti' .... maybe ????? smile, smile, smile...
OK then, has anyone else any suggestions to clear this one up ?????
Best to All....
Keith NZ
Old 19th February 2012, 05:47 PM   #4
cogsncogs's Avatar
IIRC...the codes
A=Audio Taper or Log
B=Linear Taper
C=Reverse Log
H,N,W codes were used for single/dual balance pots where at half rotation would be zero resistance one way or the other...
Color Codes Valin0r Headphone Systems 5 29th September 2011 09:31 PM
About tube codes Devius Tubes / Valves 10 4th September 2011 12:13 AM
Date codes jfitz57 Tubes / Valves 0 13th April 2010 04:37 AM
Siemens codes parrot Tubes / Valves 0 21st January 2008 06:02 AM
Textronix AM503B codes davidsrsb Equipment & Tools 5 13th February 2006 04:16 PM
Copyright ©1999-2017 diyAudio
