Old 18th February 2012, 11:31 PM   #1
bermtoog's Avatar
Default 6L6 SE Tube Amp Kit on eBay... opinions?
I was surprised to see that no information can be found on the forum because there are over 6000 hits on this auction: 6L6 SE Tube Amplifier Full Kit (12AX7 and 6L6GC) Stereo | eBay
I am looking to build my first amp and I am interested in the sub $300 range. I have ~96-98 dB speakers (Audio Nirvana full range) and the 6-10 watt range is what I am aiming for.
Looking for something with purity, warm midrange, and very few additives to the original signal. I will be using a sub/sub-amp for the lows below 100Hz.
Has anyone ever used this amp or could someone speak to the quality possibility based on the components/schematics in the auction (and perhaps speak as to why for my and other readers edification)? I am a newbie to amp design but a veteran to audio and sound in general.
Thank you for your time.
-Kevin
Old 18th February 2012, 11:34 PM   #2
bermtoog's Avatar
Output transformers:
Single-end SE Transformer 15W S15 2.5-3.5-5K:4-8 x2 | eBay
Old 18th February 2012, 11:45 PM   #3
scott17 is offline scott17  United States
scott17's Avatar
Consider the amp in my signature. A lot more expensive, it is a COMPLETE kit, and originates from the US, and I am only an email away.
FYI: OT primary inductance, 58 Henry
Scott
Last edited by scott17; 18th February 2012 at 11:53 PM. Reason: add primary inductance value
Old 19th February 2012, 12:08 AM   #4
bermtoog's Avatar
Thank you... the amp looks great and probably sounds even better but there is no possible way the wife would agree to 850.
Also, were you saying the OT should be 58H?
Old 19th February 2012, 12:41 AM   #5
scott17's Avatar
Not necessarily, however the primary inductance of this particular transformer design provides for an excellent low frequency response and it has excellent high frequency performance as well.
Thanks,
Scott
Old 19th February 2012, 12:52 AM   #6
by the time you change all the not so good components out, you could have build a better amp from scratch.
and besides point to point if done correctly outperforms the same circuit on a pc board in side by side comparisons. And its more adventureous and gradifying when your done.
Old 19th February 2012, 01:36 AM   #7
bermtoog's Avatar
Thanks,
Scott
Thanks Scott, that is certainly helpful and something I will keep in mind in the future.
Which components in particular are "not so good"? Also, are you saying I could build this same amp by sourcing higher quality parts for less than they are selling for? If not, I am still under budget constraints.
Old 19th February 2012, 02:19 AM   #8
counterfeit caps and the wrong series of dale resistors.
$7 6l6's $5 12ax7's
output transformers $40
power transformer $80
the only thing really worth keeping is the toroid, but that is debatable.
Old 19th February 2012, 02:37 AM   #9
chrish is offline chrish  Australia
chrish's Avatar
I would seriously recommend looking at the Tubelab Simple Single Ended ampSimple SE board. It is a printed circuit board but you should be able to source cheap transformers ant tubes to make a great amp at a reasonable cost. Plenty of people here have built the amp and the designer provides great support on the forum. There is a dedicated Tubelab section of this forum you should check out Tubelab - diyAudio.
Cheers
Old 19th February 2012, 03:08 AM   #10
bermtoog's Avatar
Cheers
Thank you much Chrish, that site seems very informative and useful. I will probably end up going with their design. I searched all over the internet for a very long time and somehow I never came across that site.
Cheap ($235) SE Tube amp kit, transformer and chassis on ebay aspringv Tubes / Valves 71 21st January 2013 02:36 AM
where to buy the 6l6 se amp? DonJuan Elekit 3 2nd February 2012 09:57 PM
$75 tube amp kit on eBay??? jmillerdoc Tubes / Valves 7 26th August 2011 07:08 PM
ebay TA2022 amp board w/tube pre ..opinions? Bill poster Class D 5 12th June 2011 12:32 PM
Ebay Tube Preamp Kit bcrescen Tubes / Valves 10 2nd February 2008 12:33 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
