Tube base failures
Tube base failures
Old 18th February 2012, 04:03 PM   #1
DynacoDave is offline DynacoDave  United States
DynacoDave's Avatar
Default Tube base failures
Has any one had problems with ceramic sockets and tube base alignment keys breaking of fusing to the ceramic? You can chip the base material from the socket but with difficulty.
Old 18th February 2012, 04:47 PM   #2
the_manta is offline the_manta  Germany
the_manta's Avatar
only with bakelite sockets combined with bakelite bases. I have some EL156 with that problem.
Терпенье и труд все перетрут
Old 18th February 2012, 05:24 PM   #3
speakerfritz is offline speakerfritz  United States
yes. perhaps pastic sockets give a little and ceramic don't which transfers all the stress during removal to the tube center guide.
Old 18th February 2012, 06:09 PM   #4
DynacoDave's Avatar
After the first one snapped the center pin and key off, I had to get a pair of flat screwdriver blades under tube base to pull them from the sockets. They all left a residue and bits of plastic in the sockets. I am thinking it's only with my stock of Chinese tubes.
My Russian, American, English and German tubes don't have this problem. All 8 of my Sinos have some chipping. I know most of my tubes all have some size differences but they all fit firmly in the ceramic sockets. My other amps with Belton sockets have never had any problems. I thought about just replacing the sockets but that is going to take several hours, so I think I'll put that off for a little while. Thanks for your comments. Dave
Tube base failuresHide this!Advertise here!
Repair Failures dmccloud Class D 1 30th September 2011 08:21 PM
WTB 4 Pin tube base gaborbela Swap Meet 5 27th July 2011 04:19 PM
Tube Base Application ? Troncones Tubes / Valves 3 20th February 2010 04:34 AM
What glue to use for tube glass bulb + base reaction Tubes / Valves 10 31st July 2007 04:11 PM
nedd az1 tube base in the UK Raj1 Tubes / Valves 6 28th September 2003 03:09 PM
