Tube amp left ch. hum - diyAudio
Old 16th February 2012, 09:44 PM   #1
Default Tube amp left ch. hum!
I have an Audio Electronics Super Amp MkII power amp made by Cary Audio which has left channel hum. It has been this way since I bought it used 3.5 years ago, though the hum has gotten somewhat louder since then.
Upon inspection, none of the caps (mostly Kimber) look bad, though I haven't tested them because I would have to remove them to do so. I have replaced and rotated tubes around with no change in the hum. I have made sure the point-to-point wiring is isolated as best as possible.
There is a chassis mounted headphone type plug on the rear for biasing, that seems kind of a funny design. I should mention when I plug in the bias cable to hook to a meter the hum stops. I can take a photo of this area if necessary.
What could be the problem and/or what should I test first? Here are photos of the unit.
Old 16th February 2012, 09:54 PM   #2
GloBug is offline GloBug  Canada
Banned
The usual thing to do is check and or replace electrolytic capacitors. (I'm assuming you know how to do so safely)
How old is the amp? The caps could be failing early due to heat. (85 degree caps)
The layout looks like it would humm, but you say it is getting worse and only in one channel.
Old 16th February 2012, 09:58 PM   #3
firechief's Avatar
Disconnect the inputs completly. With the power on and speakers connected, do you still hear the hum? We need to eliminate a few things first. Does the hum increase with volume? Or just stay at a low level. Do you have schematic? If so post it.
"You can keep your insurance baby nothing is guaranteed" -Tom Petty
Old 16th February 2012, 10:02 PM   #4
dagerman's Avatar
Disclaimer: I am not an expert, still learning this stuff myself.
I may be completely off, but just to see reactions of the real experts out there: The yellow wire coming off of the OPT look like they provide feedback to what could be the driver stage tube. Is it a good idea to route those right past the choke? It looks like the speaker output wires have been routed as far away from any inductors as possible.
There are 10 types of people: Those who understand binary and those who don't.
Old 16th February 2012, 10:36 PM   #5
Thanks for a super quick reply!
Amp is 2007. Are the big silver cans the electrolytic caps. What is the safe way to test? Yes, it looks like a hum design to me, but only the left channel hums.
Hum is only the left channel. It hums with no input, does not change volume, and is easily heard from 12' or more away with no source playing. Music at reasonable volume drowns out hum, that is why I never addressed it before.
Is the choke that little transformer between the output trannys. If so I moved the wire away and still hum, only in left channel.
Old 17th February 2012, 02:16 AM   #6
Banned
The choke is that little transformer between the outputs.
The electrolytic capacitors are the ones wrapped in blue plastic. If the amp is from 2007, these "should" be fine.
The big silver caps "appear" to be an oil cap, which usually last a long time.
The fact that the hum does not vary could mean the output transformer is picking up noise from the power lines/transformer.
I do notice the red wires that come from the power transformer are close to the left output transformer. If you have enough slack, use some zip-ties to move the wires away from this area a bit.
Read up on tube safety before you go sticking your fingers in there, safely discharge the capacitors first, ie: the blue electrolytics and the oil caps. It's good practice to drain all the caps until you get to know which ones are the dangerous ones.
Old 17th February 2012, 02:56 AM   #7
firechief's Avatar
Tube Compliment: 6SN7 x 3, EL34 x 4
Try pulling the 6SN7's one at a time and see if the hum goes away. If it was the power supply caps it would be common to both chanels. There is no problem running the amp with the preamp tube's removed.
6SN7 is a dual triode vacuum tube, on an 8 pin octal base. So proballly one 6SN7 is common to both channels and the other two tubes are unique to a channel. Knowing this is a big help in narrowing it down. Are you with me?
Old 17th February 2012, 03:18 AM   #8
Banned
Good tip.
Also see if you can find a schematic, what does the bias meter look like? You might be onto something with that. A manual would be good too.
Old 17th February 2012, 11:43 AM   #9
remove the bias jack; as this should be a set of bananna or a jones socket.
1/4 inch should be for signal use only and I recommend only used for input purposes (as speakers should always be speak-on connectors).
Old 17th February 2012, 01:34 PM   #10
speaker is offline speaker  United States
speaker's Avatar
The hum could go away because the tube is pulled from the circuit if the problem is upstream. Rather than remove the tubes completely, try swapping them one at a time from one channel to the other. If the problem follows the tube, you might have the culprit.
I suspect though that is not going to be the case. Even though it looks like high-quality parts were used, I'd bet you have a bad coupling cap on the hum side. If the tube swap does not yield good results, I'd replace them and see where you are.
Broken amplifier - Hum in left channel. MaxWar Solid State 7 28th April 2011 06:51 PM
Help With Left Channel Hum Monjul Tubes / Valves 4 21st April 2010 11:24 AM
Hum in left channer - rogers cadet 3 cr0wl3y Tubes / Valves 6 8th January 2010 12:44 AM
Tube Amp - Crackling Sound on Left Channel Noak Tubes / Valves 8 28th December 2005 02:46 AM
Left Ch Zenv4 Circuit Board Design Blues Pass Labs 0 21st March 2005 12:54 AM
Copyright 1999-2017 diyAudio
