Help with the modifications of my tube-amp - Page 2 - diyAudio
Old 18th February 2012, 05:29 PM   #11
NFB is debateable. always try to build the circuit perfect. if you start clipping the signal through the path, then apply NFB.
your schematic does not have it. So what. Lets fix whats really wrong instead of lowering the gain characteristics to hide problem.
for a heater transformer I would use a hammond 166ms (5vct 3A) for a each tube. the reason to stray away from 6.3V is less tube noise on the plate and better gain characteristics over the life of the tube.
now a variant of this is to take a transformer that has class F insulation split/dual bobbin type that has two 115V primaries and two 6V secondaries 50VA. Tie the primaries in series (230V operation) but run it at 120V. now we add a layer of rfi by adding a .01UF 1000V cap from the primary's center tap to the FG or earth ground (optional). Tie the two secondaries in series (normally 12V) now you have 6VCT but with core loss, this can be an advantage as any imbalance of heater winding tap will be absorbed in the heater winding core. the reason because of the higher current rating is mainly to lower the DCR of the secondary. Another effect is the extra inductance that bucks against the heater and secondary causes a small amount of heater regulation to be established as the thermionic emission will dynamically change with the signal. This sponginess works really well. And can be increased by putting 5-15mh chokes between the heater pin and the transformer connection.
in a push pull DHT amp I always recommend using separate transformers: one for the inverting and one for the non inverting side of the output section.
Old 14th October 2012, 07:32 PM   #12
hi dave.
so I need to get a hammond transformer for each output tube? so four in total?
also, is the 6a5G is a direct replacement in my amp or I need to get new sockets for those tubes?
but im not sure if you stil think I should change my 6b4g?
Old 16th October 2012, 12:10 AM   #13
anyone?
B&O Beocenter 2300 modifications swingarm Digital Source 1 18th March 2012 05:28 PM
Fender Guitar Amp modifications perfusionist Instruments and Amps 3 1st April 2011 01:50 AM
Sonic T-Amp Modifications Help Req. snoopy1 Class D 1 26th November 2006 06:20 PM
Modifications of car amp for better sound celestian Solid State 3 11th May 2006 02:44 PM
modifications to compact EL84 amp Serow Tubes / Valves 25 15th January 2003 06:52 PM
Copyright 1999-2017 diyAudio
