Old 21st February 2012, 02:25 AM   #31
FSHZ:42 is offline FSHZ:42  United States
FSHZ:42's Avatar
Originally Posted by fandersen View Post
There is no need to replace the 5751 tubes, unless you want to
I was told that the NOS GE 5751 were among the best sounding pre-amp tubes. I went to a site that has them, but they are on the high $$$ side.
I was also told that the Phillips JAN 5751 ECC's, which I am presently using, are at the bottom of the pole.
I am not sure what to believe! Maybe someone here can give me their inputs!
Thanks!!!
Old 3rd March 2012, 07:43 AM   #32
multi is offline multi  Australia
I don't think you need to run KT88's at more than 50 ma per tube.
90 ma would burn them out fast. GEC with the original KT88's, recommended that anything above 35 mills was plenty.
Phil
Old 6th March 2012, 02:37 AM   #33
FSHZ:42's Avatar
Hello Multi,
I was referring to the voltage not amperage. The GL Genalex KT88's are run on my amps at around 90mV. I run my SED Winged "C" tubes at around 62.5mV. I have not had any problems, except for the GL tubes on one amp reading out of the specific range tolerances.
It has been known that the GL tubes have had these issues in the past.
Thanks for your reply!
Old 6th March 2012, 10:10 PM   #34
Originally Posted by FSHZ:42 View Post
Hello Multi,
What do you mean by "specific range tolerances"?
Old 7th March 2012, 12:34 AM   #35
FSHZ:42's Avatar
I try to keep the voltages going into the output tubes at around a 2% tolerance. This means that if you are running a certain power tube at say 60mV (manufacturer specs recommendation @ 60mV), the 2% tolerance would be +/- 1.2mV.
This is what I meant by the "specific range of tolerances"
I left the "of" out.
Old 7th March 2012, 03:39 AM   #36
AJT is offline AJT  Philippines
AJT's Avatar
perhaps you mean mA?
or a 1ohm cathode resistor drops 60mV when a current of 60mA passes thru it....
The Rebuilding of Theta KT-88 Tube amp. Maniac Tubes / Valves 43 16th March 2013 04:24 PM
Another KT-88 cryo Tubes / Valves 23 1st October 2008 03:06 PM
Opera Reference KT-88 tube amp Ang Swap Meet 2 31st March 2008 07:21 PM
Need PP KT-88 amp design and KT-88 for triode use? Norris Wilson Tubes / Valves 7 23rd February 2005 12:12 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
