10m45s cascode diagram?
Old 5th December 2012, 09:33 AM   #11
andyjevans is offline andyjevans  United Kingdom
One point with these IXYS devices is to take care handling them - make sure your hands are grounded when you touch the pins.
Old 5th December 2012, 11:31 PM   #12
50AE is offline 50AE  Bulgaria
Although the devices alone work great as a single CCS, I just can't do the cascoded CCS, the current keeps stuck at 1mA . Could it be something to do with the gate stopper resistors?
Old 6th December 2012, 09:59 AM   #13
I had trouble with a cascode myself - not sure why. Maybe it needs greater headroom?
Old 6th December 2012, 10:01 AM   #14
On Hiatus
SY's Avatar
That would be my guess. I haven't used that device, just the DN2540. But if the transistors aren't blown, then compliance voltage may be the answer as to why. Unfortunately, the datasheet I have doesn't really show the curves...
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 6th December 2012, 11:07 AM   #15
Thanks for that, SY. I didn't have that much headroom so used a single device.
Old 6th December 2012, 11:55 AM   #16
Magz is offline Magz  United States
I have no problem with 10M45S cascodes. I make sure I have lots of headroom, though, on the order of 90-100V.
By the way, I'm using the "mu output" of the CCS in my 26 preamp and it sounds excellent, in addition to giving an output impedance of ~1500ohms. I don't hear any degradation versus the plate output - if anything it sounds better. The lower impedance allows me to run the tubes directly into the autoformer volume controls and avoid a separate output transformer. Combined with lossy parafeed the low end extension is -3dB at 4-5Hz.
Old 6th December 2012, 12:10 PM   #17
zigzagflux is offline zigzagflux  United States
zigzagflux's Avatar
Datasheet for the Supertex part indicates capacitance drops significantly once you get about 20-25V of headroom. In my uses in about 5 different amps, they run just fine with 20V. I would not suggest running them below 10 if you want decent performance. The lower the capacitance, the higher the output impedance at high frequencies.
Old 6th December 2012, 05:17 PM   #18
B+ is 300V and anode voltage is 150-160V. So 140V left for the 10m45s not enough? The current is 30mA
10m45s cascode diagram?Hide this!Advertise here!
10m45s Steven123 Tubelab 10 8th May 2011 11:39 AM
Ixys 10m45s theskintman Tubelab 0 31st August 2010 11:31 AM
Ixcp 10m45s Wombat 397 Tubes / Valves 14 4th September 2009 12:09 AM
Wtb; 10m45s Cobra2 Swap Meet 9 26th November 2008 05:17 AM
cascode diagram MichaelJHuman Everything Else 1 29th August 2005 08:06 PM
