#2 |
By applying some positive voltage to the cathode, the correct voltage relationship between the 2A3's grid and cathode is maintained. As the tube ages, less cathode current would be drawn resulting in less negative voltage appearing on the grid. (with respect to the cathode) This is especially important because the tube's grid is directly coupled to the previous stage.
"The supercomputer is technologically impossible. It would take all of the water that flows over Niagara Falls to cool the heat generated by the number of vacuum tubes required." ~ Professor of Electrical Engineering, New York University |
#3 |
It has to do with the fact that 195V across 3K is 65mA, so the 22K resistor provides the other 5mA so that the 2A3 doesn't have to.
The 22K resistor could be omitted if a 3250 ohm cathode resistor was used instead, in fact 3.3K is probably more than close enough. You would have to adjust the value of that 25K resistor to compensate for the greatly reduced current however. (Change to about 120K) You might also consider a 6SL7 in the first stage, you'll only need to tweak its cathode resistor value to get the right plate current in the first stage. (I'd probably run half a 6SL7 per channel)
"Extraordinary claims require extraordinary evidence." - Carl Sagan |
| Joplin PP 2A3 Question... | gray49 | DIY HiFi Supply | 5 | 14th June 2011 08:12 AM |
| Tubelab SE 2A3 _ Newbie question. | btran | Tubes / Valves | 14 | 21st November 2009 01:28 AM |
| WTB: OPTs for 2A3 or 45 SE; 240 v power tranny for 2A3 or 45 | rick57 | Swap Meet | 0 | 8th November 2006 01:07 AM |
| Help about SHISHIDO Pre Phono | Maurizio | Analogue Source | 1 | 9th May 2005 12:22 PM |
