Old 19th February 2012, 12:12 PM   #51
jackinnj's Avatar
Here's a GUI:
Old 19th February 2012, 04:47 PM   #52
TheGimp is offline TheGimp  United States
TheGimp's Avatar
Nice, what are you developing that in?
I was previously looking at using Microsoft Visual C++, but the learning curve is rather daunting.
Old 19th February 2012, 05:31 PM   #53
jackinnj's Avatar
Visual Basic. Originally there was a program called "Softwire" which National Instruments scooped up -- as it competed too competitively with Labview (came free with a DAC/ADC card) -- you went from a graphical connect the dots screen which wrote the code. OK for simple projects, but all it was doing was writing the code.
It is "somewhat" daunting, but it is, after, a language which gets learned with practice. You're not going to be programming stochastic models for mortgage derivatives, just some loops and controls and a graphical interface. VB is easy in this respect and there's a huge body of canned stuff out there. My C++ stinks!
Whatever you program in, it's important to remember that you've got to protect the DUT AND your instrumentation from accidental catastrophe. As Steve Ciarcia said "software in solder".
Old 19th February 2012, 06:07 PM   #54
TheGimp's Avatar
I've programmed in C, but not C++. About once every five years I end up doing some code for an imbedded project, but it is mostly take code from a previous module, strip out the module specific code and write a couple hundred lines to replace it. Nothing much. I don't code often enough to be proficient.
I would probably be better off in VB.
Old 20th February 2012, 02:54 PM   #55
Michael Koster's Avatar
Default D/A shield
Here is a first cut design for the D/A component that plugs on to the Arduino board (called a shield in Arduino-speak). I provide a +5V power input, 8 D/A outputs, and break out 8 A/D inputs.
The connectors are amp MTA and break the signals out into twisted pair or coax.
Michael
Old 20th February 2012, 04:39 PM   #56
TheGimp's Avatar
I would recommend adding a 1nF cap on the Refout/Refin pin (Spec says 1-10), change the 1uF bulk storage to 10uF and add a 1nF to VDD as well.
Old 8th March 2012, 04:56 PM   #57
I looked at the app note again and made the changes you suggest; thanks.
Here is the first PCB stuffed and ready to test, with the Arduino MEGA board it stacks onto.
I'll need to create some library code for the basic setup and operation.
Old 8th March 2012, 05:33 PM   #58
TheGimp's Avatar
Looks nice.
Old 8th March 2012, 05:35 PM   #59
Good work!
tubes.rs
facebook.com/tubes.rs
Old 8th March 2012, 05:38 PM   #60
Awesome Michael!
"People can't do what they should: room acoustics and speaker design - so they do what they can: new amps, cables etc." (Lidia)
Valve curve tracer gm tester mogliaa Tubes / Valves 13 15th February 2011 02:34 PM
What tube bases to support for a new tube curve tracer crj11 Tubes / Valves 21 6th February 2010 03:15 PM
Modifying a tube tester into a curve tracer (oscilloscope X/Y outputs) ? bembel Tubes / Valves 27 23rd October 2006 09:34 PM
Tube Tracer jackinnj Tubes / Valves 11 20th March 2006 01:10 PM
usb-programmable micro? nuppe Parts 7 6th January 2005 04:32 PM
Page generated in 0.12363 seconds (100.00% PHP - 0% MySQL) with 10 queries
Copyright ©1999-2013 diyAudio
