I own for for at least 5 years ASL MG OTL 32DT and was always satisfied with the sound however since purchase I had slightly hum at 2 o'clock but as long as pass this point it disappeared. Dead silent before or after.
I heard that some people resolved this problem but I was unable to find anywhere DIY for this. Does someone here did this mod? Mine looks like this exactly... ANTIQUE SOUNDLAB P.S. I use it with Sony's MDR 7506 and Beyerdynamic's DT931 and plan to add Grado's SR325is and AKG K701... one after one!
#2 |
Simple answer, Dont play it at 2pm!
Wait till later in the day!
Das Beste Oder Nichts |
#3 |
#4 | |
This may not be linked, however this is my tail it might or might not help.. My OTL had a hum problem at 10 o'clock before and after was quiet. It is /was linked to heater leakage in the preamp section. It did not matter if I lifted the heaters (HT divider) or grounded through 2 x 220 ohm psudo CT. The hum was still there.. The answer was to float the heaters with a 0.1 uF polypropylene cap between the heaters and Gnd. The cap charges due to any leakage and equalises the cathode to heater voltage. Regards M. Gregg
What is the sound of one hand clapping? |
#5 | |
While I am not very well versed in tube stuff or electronic, can you please explain in further details what I need to do... With good explanation I will be able to do it... ![]() Regards. |
| mission 753 crossover tweeter mod DT-284s | vincent.mester | Multi-Way | 14 | 4th March 2013 12:32 PM |
| ASL interstage transformer | bewivie | Parts | 0 | 14th November 2009 02:24 PM |
| 2.1 DT project, help needed | ACDC999 | Subwoofers | 3 | 22nd August 2009 09:07 PM |
| Monacor DT-25TI | tpsorin | Multi-Way | 1 | 18th July 2008 07:56 PM |
| ready to mod the hell out of my asl wave 8's | sleepkyng | Tubes / Valves | 9 | 29th April 2004 06:01 AM |
