How does a VAC Renaissance 70/70 get 65W from 4 300Bs?
Old 24th September 2003, 12:51 AM   #21
fdegrove is offline fdegrove  Europe
diyAudio Senior Member
fdegrove's Avatar
I like the ones which call out "single ended" and "class A" as separate virtues, as in, "not only is it single-ended, it is *also* class A". And that too, in a linestage. How many push-pull class B linestages are there? PP maybe (or more likely, balanced or differential, neither of which would be single ended, right?), but I really wonder if there are many non-class A linestages.
As linestages go most are run in Class A and SE.
If you think SRPP or White CFs are PP then that's not really PP to my mind.
Now if you want something really outside common thinking I'd use an OTL linestage running in balanced operation with a balanced constant impedance volumecontrol preceding it.
That would use a true bi-polar tube regulated supply as well...
Add a tubed Widlar current mirror to clamp the cathodes and you'd have a hell of a linestage.
And, no, I didn't patent the idea...yet.
Frank
How does a VAC Renaissance 70/70 get 65W from 4 300Bs?Hide this!Advertise here!
Anyone familiar with Hyuger HK-300BS kit from Hino Audio? truenorth Tubes / Valves 0 21st November 2007 07:51 AM
FS: Morel/Renaissance tweeters MarkHathaway Swap Meet 0 22nd January 2006 07:38 AM
Morel Renaissance MLP-403.5 Stefano Multi-Way 2 6th October 2005 08:52 AM
who knows DIGITAL RENAISSANCE? fred38 Digital Source 0 16th August 2005 07:09 PM
FS: Shuguang 300BS-C garbage Swap Meet 0 21st January 2005 12:00 AM
