Hybrid for Zobsky - Page 2 - diyAudio
Old 22nd February 2012, 01:32 PM   #11
zobsky is offline zobsky  India
zobsky's Avatar
following this thread , .. though half this stuff is over my head
should be interesting when Ken and I finally commit this design to reality
"Not everything that can be counted counts, and not everything that counts can be counted." - Albert Einstein
Old 23rd February 2012, 02:14 AM   #12
The thing driving me crazy is actually pretty simple.
Its same as any ordinary SE ultrapath sitting on CCS.
CCS impedance forces all power ripple to appear in
full at the cathode. Split tails doesn't change this
simple truth for the common mode impedance.
The proper solution is probably the same too. Add
ripple to the input signal to make them common.
Loftin White is one plausible example how it could
maybe work...
Either that, or have to filter ripple till there simply
isn't any... Or make a regulated ripple be the input.
That approach should certainly qualify as bizarre!
I mean, like if you left the grid and gate at ground
reference level, and drove the supply ripple instead.
The ultrapath loop would thus be forced to circulate,
because transconductance is purposefully not the
same on both sides. Yeah, go figure...
Zobsky ponders the Aura NS6-255-8A zobsky Multi-Way 26 9th June 2012 04:39 AM
Hybrid never see Stee Tubes / Valves 11 2nd August 2011 08:37 PM
the hybrid one arhi45 Tubes / Valves 11 8th May 2007 08:44 PM
My wacky idea for a hybrid horn loaded woofer/planar widerange hybrid loudspeaker. Spasticteapot Multi-Way 0 30th November 2006 04:16 AM
Copyright 1999-2017 diyAudio
