diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Tubes / Valves (http://www.diyaudio.com/forums/tubes-valves/)
-   -   Copland CTA-401 - early layout ? (http://www.diyaudio.com/forums/tubes-valves/206556-copland-cta-401-layout.html)
jesper2603 12th February 2012 01:15 PM
I have purchased an early version of the CTA-401 as the print layout in the amp and the schematics found are quite different: no relais-driven input, a smal separate print mounted vertically and the power supply capacitors are quite different to the pictures I have seen.
Question: I need a tube layout description (5 x ECC8n) on the print - some without name - are they all ECC83 ?
Has somebody a schematics with the values ?
Thanks.
Resources saved on this page: MySQL 18.75%
