1AG4 Direct Heated Pentode, Output
Old 18th February 2012, 08:08 PM   #11
DavesNotHere is offline DavesNotHere  United States
Oh yea, I forgot my DI box project where I used phantom to power the tube. used a resistor-led tied off from phantom and put the heater across the led. My output circuit was SE, 12K output impedance, 1.3mA
Old 18th February 2012, 09:19 PM   #12
TheGimp is offline TheGimp  United States
TheGimp's Avatar
Interesting DavesNotHere,
I tried battery power and found the current source to be as quiet (at least in measurement). I will probably give it another try when I do the listening tests.
Right now I'm running 30V B+, but I tried 60V and got basically the same results (maybe in part due to this being a LTP with a current source in the tail)?
1AG4 Direct Heated Pentode, OutputHide this!Advertise here!
Direct heated tubes with centre tap on filament mig-ru Tubes / Valves 21 15th August 2017 06:01 PM
A directly heated triode or Pentode SE amp on a Budget avisa Tubes / Valves 24 7th March 2009 11:16 PM
Best low-signal direct heated triodes? gentlevoice Tubes / Valves 7 5th May 2008 03:03 AM
Spice 3f4 model of a low voltage direct heated signal level pentode wa2ise Tubes / Valves 0 24th April 2006 12:18 AM
