Can you make 0-5V DC out of 2.5-0-2.5V AC - Page 2 - diyAudio
Old 23rd September 2003, 02:20 PM   #11
diyAudio Moderator Emeritus
Bas Horneman's Avatar
Will proceed with my 0-14V solution and try to get rid of the heat.
You could still go for the "passive" 5VDC solution as well? What is the problem there? Many report that it sounds better than regulated.
Bas
planet10 needs your help:
Let's help Ruth and Dave
Old 23rd September 2003, 02:21 PM   #12
moamps is offline moamps  Croatia
Originally posted by dhaen
Good idea (again) moamps
Thanks, John!
Old 23rd September 2003, 03:03 PM   #13
Ralph is offline Ralph  Netherlands
Ralph's Avatar
Hi moamps
If your secondary 5V is unused, connect them serial and out of phase with 14V secondary. You will get 14-5=9V AC on bridge. Strange idea but works.
Interesting but I don't fully understand yet
I have two secondaries, 2.5-0-2.5 and 0-14V. Let's give them a letter for identification.
wire A: 2.5V
wire B: 0V
wire C: 2.5V
wire D: 0V
wire E: 14V
Which wires should I connect together now?
Thanks very much,
Ralph
Old 23rd September 2003, 03:08 PM   #14
dhaen is offline dhaen  Europe
dhaen's Avatar
Ralph:
Link A to D
Connect C and E to the bridge rectifier.
You can subtract as well as add voltages..
Edit:
Oops. Of course it depends on the phase of the 5v winding.
You may need to:
Link C to D
Connect A and E to the bridge rectifier
Old 23rd September 2003, 03:13 PM   #15
dhaen's Avatar
Ralph,
You'll have to do this by trial and error, I think.
Don't connect to the bridge rectifier until you are sure.
In one phase the voltages will add, in the other they'll subtract; that's the one you want.
Old 23rd September 2003, 03:13 PM   #16
Ralph's Avatar
Hmm sounds scary but will try it. Connect B to ground or just leave it alone? And I can just connect either configuration and check with a multimeter, right?
Old 23rd September 2003, 03:19 PM   #17
dhaen's Avatar
Default It's not scary
Ralph,
Don't connect any transformer terminals to ground.
Old 23rd September 2003, 03:20 PM   #18
dhaen's Avatar
Yes, just use the multimeter to start with.
Make it worse to make it better??? moray james Planars & Exotics 23 12th May 2008 11:08 AM
What to make? Mayday Tubes / Valves 3 5th December 2006 03:20 AM
Make ac dc. Jasmeleg Parts 12 12th September 2005 06:14 PM
How make make a microchip, from a program? multiplexor Everything Else 1 20th February 2004 01:24 PM
Copyright 1999-2017 diyAudio
