Can you make 0-5V DC out of 2.5-0-2.5V AC
Old 23rd September 2003, 01:31 PM   #1
Ralph is offline Ralph  Netherlands
Ralph's Avatar
Default Can you make 0-5V DC out of 2.5-0-2.5V AC
Suppose not, but had to ask ...
edit: and make it good enough to use as 300B filament supply
Old 23rd September 2003, 01:36 PM   #2
Bas Horneman is offline Bas Horneman  Netherlands
diyAudio Moderator Emeritus
Bas Horneman's Avatar
Default Bas Horneman
Yes you can..
2,5v..................wire 1
0
2,5 ....................wire 2
gives you 5V AC across wire 1 and 2
Rectifier + caps gives you 5 * 1,6 for cap input PSU..is 8VDC.. (roughly)
7805 gives 5vdc regulated at 1A
or voltage dropping resistor (depending on current draw) to give 5vdc unregulated..
Bas
If you can see the speaker cone move...it's not hifi.
Old 23rd September 2003, 01:41 PM   #3
dhaen is offline dhaen  Europe
dhaen's Avatar
You have to take account of the drop across the rectifiers:
Schottky rectifier bridge, and a big resovoir cap.
Is it a heater supply?
Old 23rd September 2003, 01:46 PM   #4
Ralph's Avatar
Yes, it's a 300B filament supply. At this moment I'm using 0-14V AC to get 0-5VDC and that gives quiet some heat. And because the 2.5-0-2.5 was still available when I used AC I thought I might be possible ... but I'm afraid voltage will be too low to use a regulator. My 300B draws 1.41A @ 5V.
Old 23rd September 2003, 01:46 PM   #5
If that is the point of the exercise...you should use Schottkey IMO.
And go for a simple current regulated LM317 jobby..
Did you not buy the circuit boards from Doede?
Bas
Old 23rd September 2003, 01:55 PM   #6
dhaen's Avatar
Ralph,
Where is the 2.5-0-2.5 coming from?
If it's from an enclosed transformer, that you can't overwind, there are other solutions to "find some volts".
If you buy a small (15 or 30VA) toroid, you can hand wind some turns - perhaps 3 turns per volt, to put in series with the existing, to make the exact voltage required.
Sorry for the long rambling English. I'll clarify if you're interested.
Old 23rd September 2003, 02:03 PM   #7
Ralph's Avatar
Hi John,
Clear enough for me The trafo is indeed closed and I think I'm just out of luck. Will proceed with my 0-14V solution and try to get rid of the heat.
Thanks, Ralph
Old 23rd September 2003, 02:10 PM   #8
dhaen's Avatar
Ralph,
If you are using a regulator, there is another way to reduce it's heat dissapation: You should reduce the value of the resovoir (smoothing) cap. This will increase the ripple to the regulator, and thus reduce the RMS voltage and the power. You must be careful not to reduce it too far. The voltage at the bottom of the ripple must still be enough for the regulator to operate correctly.
If you haven't got a scope, you can use a multimeter on AC range to check the output DC for ripple "break-through". Keep reducing the cap until the ripple breaks through, then go back one step.
Old 23rd September 2003, 02:13 PM   #9
moamps is offline moamps  Croatia
If your secondary 5V is unused, connect them serial and out of phase with 14V secondary. You will get 14-5=9V AC on bridge. Strange idea but works.
regards
Old 23rd September 2003, 02:16 PM   #10
dhaen's Avatar
Good idea (again) moamps
Can you make 0-5V DC out of 2.5-0-2.5V ACHide this!Advertise here!
Make it worse to make it better??? moray james Planars & Exotics 23 12th May 2008 11:08 AM
What to make? Mayday Tubes / Valves 3 5th December 2006 03:20 AM
Make ac dc. Jasmeleg Parts 12 12th September 2005 06:14 PM
How make make a microchip, from a program? multiplexor Everything Else 1 20th February 2004 01:24 PM
Copyright ©1999-2017 diyAudio
