diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Tubes / Valves (http://www.diyaudio.com/forums/tubes-valves/)
-   -   Honeywell Mercury Tube? (http://www.diyaudio.com/forums/tubes-valves/206458-honeywell-mercury-tube.html)
fid 11th February 2012 07:28 AM
Hi Folks,
I came across what looks like an old tube. It has mercury inside of it - sloshing around. It says Honeywell Regulator Company on a green label, and has some numbers on it. Is this something I should throw away? Anybody know what it's from?
flatheadmurre 11th February 2012 07:44 AM
Sounds like some kind of mecury switch.
Enzo 11th February 2012 12:44 PM
I associate mercury with high voltage rectifiers, but the memories are 50 years old.
Mercury-arc valve - Wikipedia, the free encyclopedia
Mercury-Vapor Rectifier Tubes | High Fidelity Tubes
From our very own forum:
http://www.diyaudio.com/forums/tubes...-question.html
http://www.diyaudio.com/forums/tubes...er-supply.html
fid 11th February 2012 06:02 PM
Photos Of Mercury Tube
Ok, here are a couple of pictures of this tube. The number on the label is: 63S-4 KX. The "6" and the "3" were very hard to see, so they might be wrong - but that's the best I could get.
http://i37.photobucket.com/albums/e9...rcuryTube2.jpg
http://i37.photobucket.com/albums/e9...rcuryTube1.jpg
riccoryder 11th February 2012 06:16 PM
That's a mercury switch. They're valuable to some people. They make great switches with contacts that never wear out. It'll last as long as the wires do. Some older thermostats used them. It's probably better than what's used in electric heaters to shut them off if they tip over. You're better off selling it to someone that can use it (Ebay maybe?), or giving to a metals recycler that sells mercury. It's valuable, but very toxic waste if not handled properly. Don't break it open, put it in the trash or with recycled bottles/cans. Those curious about mercury rectifiers might get data sheets for the 866A and 872. They're low-voltage drop rectifiers, but may need a 15 minute warm up to vaporize the mercury before turning on the high voltage. Most AM broadcasters with tube type transmitters from the 50's using them replaced them with silicon rectifier modules combining strings of diodes to handle the voltage..
fid 11th February 2012 06:26 PM
Ok, thanks for that. I'll put it on ebay later tonight, rather have somebody who knows the value of it and can put it to use be in possession of it. Don't know what it's worth, though .
Originally Posted by riccoryder (http://www.diyaudio.com/forums/tubes-valves/206458-honeywell-mercury-tube-post2902269.html#post2902269)
Resources saved on this page: MySQL 18.75%
