diyAudio Sponsor
Old 11th February 2012, 02:25 PM   #11
You don't get it; more tubes, more sound :-)
Retail price of this amp is 3000$, i would expect more serious approach for this much money.
Old 11th February 2012, 03:01 PM   #12
jackinnj's Avatar
Originally Posted by kevinkr View Post
Actually I read the article this morning and I guess this is the so called grape vine effect. The assertions made in this thread are at best inaccurate. The amplifier has 4 EL34, two 12AU7 and two 12AX7. Except for the filaments the 12AX7 are not connected, Art Dudley comments pretty forthrightly about this and dug far enough to determine that the reason is that the manufacturer uses a standard chassis and had two holes to fill. (Why the manufacturer did not cap the unused holes is a mystery IMHO.)
Jack didn't quite get the story straight.. This is a tube amplifier and has an all tube signal path. Looks quite nice too.
I read the article twice, as I remember the Tom Carvel commercials
$2,999 and they can't have a new chassis stamped out?????. Even in the US you can get these things banged out and powder-coated with a high gloss finish for a couple of bucks.
If I told one of my industrial or retailer customers that they'd have to take the part with the extra holes, I would be laughed off the trade-show floor. They could have filled the holes with some Bondo.
Old 11th February 2012, 04:18 PM   #13
What a waste of 12AX7s. I'm surprised they'd use a 12AU7 for the input stage. And that still seems a bit odd. With an extra socket per channel it would be very easy to add a direct-coupled cathode follower driver to support driving grid current. That may not be needed with the current output tubes but it would allow higher power if other tubes were ever used and would still add the advantage of no blocking distortion when the amp is over-driven. A 12AU7, 6CG7/6FQ7 6GU7 or 12BH7 would all work well for that. Just a tube and two resistors per channel, and possibly improvements to the negative supply needed. Perhaps they had that feature before and removed it thinking inferior output tubes couldn't take it? Some of the new tubes being made don't fully conform to the original specs. Perhaps someone knows what other amps they sold with that chassis?
Last edited by riccoryder; 11th February 2012 at 04:24 PM. Reason: eyes will focus any time now...
Old 11th February 2012, 05:31 PM   #14
M Gregg is online now M Gregg  United Kingdom
M Gregg's Avatar
Only comment,
Bling Bling....Well why buy an amp with less tubes when you get more tubes for your money...side by side with another amp?
If you don't know they are not connected..whos going to ask in the shop?
And I don't believe they had spare holes..
M. Gregg
What is the sound of one hand clapping?
Old 11th February 2012, 06:29 PM   #15
kevinkr's Avatar
Originally Posted by dirkwright View Post
I'm surprised that he can hear anything above 5kHz. How old is he now?
He does the technical measurements, Art Dudley who is <warning> around my age wrote the actual review which I found to be even handed and raised valid issues about the quality of construction and overall sonic performance.
People ought to read things before they comment.
The amplifier is a very conventional design with a two stage RC coupled driver stage and parallel SE output stage with fixed bias. It's biggest claim to fame might be that review be believed it works and sounds OK, and is built right here in the U.S.A by a recent start up which IMHO is kind of cool.
FWIW I do agree that the unused 12AX7A per channel is lame.. A simple anodized plate installed from the inside would have looked fine, perhaps coined so that the top is flush with the amplifier chassis.
Mark ups by distributors and dealers in some instances can almost double the price of a product by the time it gets into the buyer's hands, and mark ups of 40% to 50% are not unusual by the dealer - ever wonder why they can sometimes afford to discount so heavily?
www.kta-hifi.net
Old 11th February 2012, 06:30 PM   #16
There were companies charged with fraud in the U.S. in the 60's after it was discovered that transistor radios were being sold advertised with more transistors but they just had the leads soldered together or were using them as diodes. Some 12 transistor radios still had only six acting as transistors. This should be investigated to confirm the facts, and action taken if there is fraud. Seeing tubes that don't do anything misleads customers. Marking one type of component with the type number of another of similar but different specifications may be fraud in other cases.
Last edited by riccoryder; 11th February 2012 at 06:47 PM. Reason: question answered already
Old 11th February 2012, 06:42 PM   #17
kevinkr's Avatar
Originally Posted by jackinnj View Post
<snip>
<snip>
No doubt, it is a lot of money for a simple parallel SE amp with a 12AU7A for a driver..
I guess in high enough volumes you would possibly be right about the cost of getting chassis made and painted, in the volumes I built stuff it was not feasible at anything approaching a reasonable cost and that forced me to go to an offshore OEM for the lower cost amp line.. (Which in itself turned out to be quite a can of worms due to shipping issues - mostly damage in transit.)
I think this guy made an error in judgment from several perspectives, and I suspect he will come to realize that pretty quickly, the market will/should speak to that.
www.kta-hifi.net
Old 11th February 2012, 06:46 PM   #18
kevinkr's Avatar
Originally Posted by riccoryder View Post
There were companies charged with fraud in the U.S. in the 60's after it was discovered that transistor radios were being sold advertised with more transistors but they just had the leads soldered together or were using them as diodes. Some 12 transistor radios still had only six acting as transistors. What country are these amps sold in? This should be investigated to confirm the facts, and action taken if there is fraud. Seeing tubes that don't do anything misleads customers. Marking one type of component with the type number of another of similar but different specifications may be fraud also.
They are built and sold here in the USA, and as long as the fact that the 12AX7A perform no useful function other than eye candy has been disclosed there is no fraud. This is stated pretty clearly in the review if not quite worded that way.
A subscription to Stereophile is $10 a year for 12 issues if you shop around, so much easier to get the magazine, read the article than to speculate about what was written.
There is even a review of Thorsten Loesch's new RMA DP-777 DAC with measurements from several operating modes in this month's edition.
www.kta-hifi.net
Old 13th February 2012, 06:57 PM   #19
Atkinson is the "honest broker" -- like Diogenes carrying a lamp in the daylight, but more subtley if you read the measurements portion of the reviews.
Assuming your question is not meant rhetorically, I'm 63. I have my hearing tested regularly and it still fall within the bounds of "normal" up to the 8kHz limit of the conventional audiologist test. However, when I test speaker impedances, I do so by sweeping a tone down from 50kHz to 10Hz at a low level. I always log when I start hearing the tone; these days, it is around 15.5kHz.
Note, BTW, that research by Toole and Olive suggests that presbycusis (the normal loss of high-frequency sensitivity with advancing years) does not have a negative impact of audio value judgements at lower frequencies. What does affect the consistency and accuracy of a listener's value judgments is low-frequency hearing loss, such as that caused by close proximity to firearms.
Thanks for reading Stereophile.
John Atkinson
Editor, Stereophile
Old 13th February 2012, 07:29 PM   #20
dirkwright's Avatar
John Atkinson
Editor, Stereophile
Thanks for sharing and yes I am surprised, considering the poor condition of my own hearing at the age of 52.
From old Philips tube books , just for tube audio DIY friends ! banat Tubes / Valves 25 1st January 2012 12:19 PM
Can the 7AK7 computer tube work as audio output tube ? aldovan Tubes / Valves 10 24th August 2011 06:22 PM
OT for audio but still tube Andrewbee Tubes / Valves 1 12th August 2008 04:29 PM
Cool tube I came across... could it be used for audio? Mach_Y Tubes / Valves 52 12th January 2008 01:13 AM
A new audio tube HollowState Tubes / Valves 50 23rd December 2006 05:41 PM
Page generated in 2.07270 seconds (6.42% PHP - 93.58% MySQL) with 10 queries
