Adding a Headphone output to my amp.
Old 10th February 2012, 10:28 PM   #1
Roulston is offline Roulston  Australia
Default Adding a Headphone output to my amp.
I have a small and very nice SET value amplifier that with only about 10 watts gives me all the SQ I need in my DEN.
However ther are times that for reasons of family harmony I would like to be able to listen via heahones instead. My study ajoins the master bedroom and my wife can clear be kept awake.
The out put impedence is sufficently low for my phones which are 32 ohm. So I do not think I need any additonal impedence matching transformers but simply an attenuator, if that.
if I simply had a speaker a/b switch would that suffice? The low output Z of the amp, will provide sufiicent dampening for the phones, at 32 ohms I guess the phone provide anought load for the amp.
Am I missing something. I dont want to break my amp nor my custom Grado phones.
Cheers, Tony
P.s. maybe volume 4 of Morgan Jones book holds the answer ;-)
Old 10th February 2012, 10:34 PM   #2
aardvarkash10 is offline aardvarkash10  New Zealand
aardvarkash10's Avatar
parallel a suitable resistor with the headphone output to reach the design Z load of the output transformer.
Either use a separate a/b switch or, if you are a bit lazy, a headphone jack that automatically does the switching.
Done.
"It may not be easy for some to not hear differences, even if they are not there." - Vacuphile,
Old 10th February 2012, 10:53 PM   #3
Thanks for that advice, so use the resistor in parallel to make the 32 ohm phones 8 ohms.
So by my calcluations a 10 ohm resister get me close enough at just under 8 ohms.
Old 10th February 2012, 11:09 PM   #4
yeah, I'd aim a little higher - a 15 ohm parallel will give you 10 plus a bit ohm total load. Thats really just a matter of personal preference - Id rather the Z was set up slightly above the nominal since it has a nasty habit of going low at some frequencies. If you can get a frequency plot of your Grados that will make it a little clearer and your decision more fact-based!
Old 10th February 2012, 11:10 PM   #5
a fuse in the headphone circuit would be a good idea too - you are going to be able to SERIOUSLY overdrive them, and I'd rather blow a fuse than my Grados
Old 10th February 2012, 11:26 PM   #6
Great points. I intend to build his into a small control box on the side rather than make any direct changes to the amp. I intend that the box will contain speaker output posts, amp inputs, a switch for phone to speaker, so I can keep teh phone plugged in, a fuse for the headphone circuit and the parrellel resistor.
Thank you all.
Old 11th February 2012, 04:41 AM   #7
db! is offline db!  Canada
Take a look here:
Headphone Adaptor for Power Amplifiers
If you decide to use a fuse, remember to connect the fuse(to your headphones) after the parallel resistor. Otherwise, if the fuse blows, your OPT will become unloaded and will arc itself to death.
Old 11th February 2012, 05:01 AM   #8
jcx is offline jcx  United States
fuses only prevent fires - seldom "protect" equipment
serious amps have relays or output crowbar circuits to protect speakers - and by extension headphones that cost as much as speakers
a output transformer prevents DC from ever reaching the load
sensitive headphones may be better matched to a audio power amp with a power rated resistive divider
Old 11th February 2012, 05:10 AM   #9
Thanks all.
DB, that circuit seems to be spot on.
Old 11th February 2012, 07:22 AM   #10
dsavitsk is offline dsavitsk  United States
dsavitsk's Avatar
Adding a Headphone output to my amp.Hide this!Advertise here!
Adding Subwoofer output to Sonic T-Amp HolyGhostFire20 Class D 4 23rd November 2011 07:33 PM
adding output tubes etc to pre amp pforeman Tubes / Valves 1 2nd February 2009 06:02 PM
adding a headphone jack Bama Slamma Headphone Systems 1 13th March 2007 01:36 PM
need help with adding headphone output to S5 Electronics kit / K501 kit Neville Headphone Systems 0 29th January 2007 09:23 PM
Adding 1/4" output to telephone handset RJSkypala Instruments and Amps 6 6th March 2006 08:08 AM
Copyright ©1999-2017 diyAudio
