6N16 12x preamp srpp/cathode follower with printed circuit board design.
Old 18th February 2012, 05:34 PM   #11
Koifarm is offline Koifarm  Netherlands
Koifarm's Avatar
Today i build a headphoneamplifier with the 6N16 tubes.And it sounds realy good. Below the schematic and some specs.
You can bypass/remove U1 and U3 if there is enough input voltage(1 to 5V).
Specs:
Freq. = 10hz to 100Khz +/- 1 db.
Output power= 5 to 30mW a channel, depending on inputvoltage and headphone impedance.
Output impedance = 16 to 500 Ohm.
Total anode current = 27mA
Total heater current = 1580mA
Ronny
Old 19th February 2012, 06:19 PM   #12
mace1337 is offline mace1337  Netherlands
Hopefully tomorrow I'll be able to get a board made for your preamp design Ronny.
I'll post some pics if I do.
Ivo
Old 19th February 2012, 06:36 PM   #13
Koifarm's Avatar
Very nice Ivo.
Today i have made the PCB design for the Headphoneamp version.
Here the PDF.
http://www.ict-net.net/6n16hoofdpcb.pdf
I have left extra space to use your favourit condensators.
Old 21st February 2012, 09:27 AM   #14
My print is being developed as we speak.
Ronny, what would I need to change if I wanted to experiment with higher voltage and current?
Ivo
Old 21st February 2012, 03:08 PM   #15
Koifarm's Avatar
Ivo
R12 and R17 need to be 2Watt. And Heater voltage must be elevated with half the anodevoltage.
Ronny
Old 21st February 2012, 03:18 PM   #16
merlin2069er is offline merlin2069er  Canada
merlin2069er's Avatar
Send a message via MSN to merlin2069er
Very nice. I liked how you put them on IC sockets.
Do these tubes need to be matched? oh, what's with the timing circuit and relays?
Old 21st February 2012, 03:59 PM   #17
Koifarm's Avatar
I also use 2 sockets with one tube, i solder one socket on the tube and one on the PCB. Now they can be connected and removed very easy.
Matching is always better, but until now i have only very small variations within my batch of tubes.
The output delay( 20sec) is a build in security for as the cicuit behind the preamp does not like or can not handle the DC voltage sweep when the tubes are warming up.
Old 21st February 2012, 06:00 PM   #18
Koifarm's Avatar
This evening i did the smurfs modification on my sons 6n16preamp.
Old 21st February 2012, 06:14 PM   #19
Wavebourn is offline Wavebourn  United States
Designer & Technologist
Wavebourn's Avatar
Remove couple of capacitors from cahtodes. You don't need them in reverse polarity, it is always + on cathode in respect to ground.
Nothing in the universe is perfect. The ideal things are the ones that are most optimal. Optimization criteria, what matters. When I hear "No Compromise Design", I want to take a sledgehammer and test how impact-proof it is.
Old 21st February 2012, 06:48 PM   #20
Koifarm's Avatar
The reason i use two capacitors in the output from the headphoneamp is the size of them. one 50v capacitor is higher them 2 x 25v capacitors. Now the PCB fits in a 50mm high housing. Futher i parallel them with a 4,7uf MKP wima capacitor. This is a personal preference.
Ivo, there is also a thread regarding the 6n16 preamp on a dutch forum.
In case you do not know.
http://www.zelfbouwaudio.nl/forum/vi...hp?f=7&t=15244
Ronny
6N16 12x preamp srpp/cathode follower with printed circuit board design.Hide this!Advertise here!
Cathode follower & SRPP q Cobra2 Tubes / Valves 4 22nd February 2008 01:15 PM
Making a low distortion cathode follower preamp by brute force bigwill Solid State 0 12th May 2007 04:53 PM
Schematic please? SRPP with current source cathode follower riotubes Tubes / Valves 0 7th January 2007 05:18 PM
Question about direct coupling a anode follower into a cathode follower. G Tubes / Valves 45 29th July 2004 06:47 PM
srpp or m-follower? GAK Tubes / Valves 28 3rd September 2003 06:44 PM
