| diyAudio Sponsor | ||
#11 | |
cheers, Douglas
the Tnuctipun will return |
#12 |
Bandersnatch,
This is what I was referencing on Duncan's page; AB1 U/L 40% 553 -75.0 2x50 4500 100 2.0 I didn't mean -75 volts bias. This spec is for voltage on grid 1. If I'm reading Morgan correctly the - sign is for inverting not negstivr voltage. I thought that was the spec for the input voltage. Sorry |
#13 |
No, you've had it right the first time. 50 mA/tube idle with g2 and plate at 553 volts. 100 watts out at 2% distortion with a -75V bias on g1.
On LTP gain it is about mu/2 each plate to ground, it is mu plate to plate( this is one grid driven, the other grounded). cheers, Douglas
the Tnuctipun will return Last edited by Bandersnatch; 10th February 2012 at 05:20 PM. |
#14 |
Hey Guys,
Is the drive voltage simply a function of gain? Or does a greater voltage swing give better quality sound? Like more dynamic range? |
| How to bias Long tail pair....?? | RRITESH | Solid State | 83 | 15th August 2011 05:20 PM |
| Long-tail pair phase splitter | sdinfo | Tubes / Valves | 14 | 21st September 2010 12:35 AM |
| Long Tail Pair Linearizer | Electrone | Solid State | 17 | 21st April 2009 02:25 PM |
| 5687 long tail pair | NickC | Tubes / Valves | 7 | 14th May 2002 01:04 PM |
| Page generated in 0.07735 seconds (70.03% PHP - 29.97% MySQL) with 10 queries |
