| diyAudio Sponsor | ||
If anyone knows how to test a 5AR4 rectifier on the Hickok 752A I would really appreciate any advice, I can't find this tube on the roller sheet.
Thanks in advance, newdog. |
#2 |
The 5AR4 is listed in the foreign & supplementary test data. These are available on eBay for $10 and well worth the price. (Glendale Manuals)
Fil: 5.0v selectors: 8200-6400 bias: 0 shunt: 68 mult: SH press: S3 min mut cond: 650 note 1: For dual triodes make normal leakage test first, then repeat leakage test for second section with button S8 pressed down and held. Proceed with 1st section Gm test with S8 released. For 2nd section test on all dual tubes, press down and hold button 8 together with button listed in PRESS column.
"The supercomputer is technologically impossible. It would take all of the water that flows over Niagara Falls to cool the heat generated by the number of vacuum tubes required." ~ Professor of Electrical Engineering, New York University Last edited by HollowState; 10th February 2012 at 01:15 AM. |
#3 |
Thank you so much!
newdog |
| Hickok 752A calibration? | dgta | Tubes / Valves | 41 | 7th January 2012 11:21 PM |
| EF86 on HICKOK 752a tester..?? | gianis | Tubes / Valves | 1 | 27th December 2011 10:20 PM |
| Rectifier tube 5AR4 vs. 5U4GB? | Ty_Bower | Tubelab | 31 | 11th October 2011 04:57 AM |
| test settings hickok i177B for 5ar4/gz34 | kathodyne | Tubes / Valves | 3 | 12th November 2008 07:40 AM |
| Hickok 752A repair | farriswheel | Tubes / Valves | 2 | 22nd June 2008 10:44 PM |
| Page generated in 0.07757 seconds (64.34% PHP - 35.66% MySQL) with 10 queries |
