Old 9th February 2012, 05:56 PM   #1
no gas is offline no gas  United States
Default 6n23 v. 6dj8 v. 6fq7
I've been playing with these three tubes and would like to know who uses which and why. So far I find that the 6fq7 sounds best in my KT88 SE amp. It is the most extended and quietest. The 6n23 has more hum than the 6dj8 but the have the same tonal qualities. Are there any others I should try?
My stuff: MC30, MC225, MX110, PAS3, ST-70, RH-84, HK A224 and a lot of parts waiting for time.
Old 9th February 2012, 06:13 PM   #2
DF96 is offline DF96  England
6n23 and 6DJ8 are essentially the same valve. 6FQ7 is different, but just happens to have the same pinout. I would use the one intended by the designer of your amplifier.
6CG7/6FQ7 = 6N5P (6Н5П) lordearl Tubes / Valves 9 3rd December 2011 09:21 PM
6FQ7 in RH84 ThSpeakerDude88 Tubes / Valves 5 22nd December 2008 08:48 PM
6DJ8 alternates? whitelabrat Tubes / Valves 18 23rd June 2008 02:01 PM
6gu7 a sub for 6cg7/6fq7? jarthel Tubes / Valves 5 17th May 2007 07:35 AM
6DJ8 Tubes Tom D Tubes / Valves 24 26th June 2006 11:39 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
