| diyAudio Sponsor | ||
#11 |
I have re-built many of those exact Zenith consoles into RH84 and can say they sound great!! Should work out great.
#12 |
I agree that a RH84 with the Zenith "iron" should be fine. If the approx. 2 WPC triode wiring yields is acceptable, following the DECWARE SE84 design will work out. If a SE84 knock off is tried, use a current production, Russian, 5AR4 as the rectifier, which will increase the B+ rail voltage. The forward drop in a 5Y3 is quite large.
BTW, watch the phasing of the O/P trafos. Zenith was "cute" and used the 6BQ5s as a mono push/pull amp for a single bass driver. "Cheap Charley" strikes again.
Eli D. |
#13 | |
"Part of the reason a poot into a toilet bowl sounds the way it does is because of phase shift." -Andrew Eckhardt |
#14 |
frugal-phile(tm)
A 10k>8 OPT can also be considered a 5K>4 OPT
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#15 |
True, as Globug already pointed out.
#16 |
Wow Thank you all! I am learning a lot, This looks very promising I think I now need to sit down and reread all of this a few times so it sinks in and then start disassembling the Zenith Chassis. Then I need create a parts list and get some things ordered. I am sure I will be asking for your help again real soon as I actually start the build,
| RH84 SE, pentode driver... advice please | bigjppop | Tubes / Valves | 146 | 17th October 2011 03:49 AM |
| Noob needs woofer advice =D | spellwords | Subwoofers | 12 | 22nd August 2011 09:32 PM |
| Ambitious Noob looking for advice. | mental2k | Chip Amps | 5 | 22nd July 2011 04:47 AM |
| Noob looking for some advice | MrBurd | Tubes / Valves | 13 | 18th June 2011 06:29 PM |
| Page generated in 0.08794 seconds (72.14% PHP - 27.86% MySQL) with 11 queries |
