No output transformer tube amp
Old 9th February 2012, 07:25 AM   #1
heinz1964 is offline heinz1964  Denmark
Default No output transformer tube amp
Hi
Is it possibel to make a tube amp without output transformers.
I am thinking of a sort of line array with lots of seriesconnectet fullrange loudspeakers.
If you have 20 or more 4" speakers with 8 ohm impedance in series you get a load of at least 160 ohm is that enough?
best regards
Uwe
Old 9th February 2012, 08:39 AM   #2
hidnplayr is offline hidnplayr  Belgium
hidnplayr's Avatar
Yes it is possible, search for OTL amplifiers.
Here is an article on tubecad about the subject: OTL Amplifier Design
Real tubes have top-caps
Old 9th February 2012, 08:40 AM   #3
hitsware is offline hitsware
OTL Asylum
Old 9th February 2012, 09:32 AM   #4
FullRangeMan is offline FullRangeMan  Brazil
FullRangeMan's Avatar
Originally Posted by heinz1964 View Post
Hi
best regards
Uwe
An old OTL amp, seems the first one, used one(1) special made to order fullrange driver with 600 Ohms impedance.
About the line array, I sorry inform you that various series connected FR will delivery a slow sound, how many drivers, how many slow?? +Just a real test may say.
I remember a great book(missing the name) from Eng.Bessel, where he test various series LA, with 1 out of phase driver in the center.
If you can read this book, it will help a lot.
>Never go to a psychiatrist, adopt a cat or dog from the streets. On the streets pets live only two years average.
Old 9th February 2012, 09:40 AM   #5
This is the best LA I see today, no tweeters as the PipeDreams, it use 25 small fullranges.
But it use a EQ discrete box to boost the bass.
WWW.IDS25.COM
Old 9th February 2012, 08:40 PM   #6
SemperFi is online now SemperFi  Wake Island
As a compromise I built a pair of speakers with a single fullrange x-over'd at 300Hz, and have two series connected woofers below the x-over. Gives a system with 8ohms where less power is needed and 16ohms where more is. Most OTLs deliver about twice as much power into 16ohms than 8, so it works out pretty ok. I use a Fostex 6" (can't remember nomenclature, it's the one with mag-shield) and two SEAS 8" woofers. Turned out to have pretty close sensitivity so didnt need to pad either drivers. Not the best speakers perhaps, but a nice easy load for my OTLs.
There are some 16ohm drivers out there, but very little information about them. I wish there was more attention into higher impedance drivers, not only for OTLs, but also tube amps could use less turns ratios in the output trannies, which is very beneficial.
Old 9th February 2012, 09:23 PM   #7
Wavebourn is offline Wavebourn  United States
Designer & Technologist
Wavebourn's Avatar
WWW.IDS25.COM
I did that once in restaurant: using 31 - band EQ I made 12 dB/Oct bust below 80 Hz of my line arrays. Sound quality was magnificent, though loudness was very low.
Nothing in the universe is perfect. The ideal things are the ones that are most optimal. Optimization criteria, what matters. When I hear "No Compromise Design", I want to take a sledgehammer and test how impact-proof it is.
No output transformer tube ampHide this!Advertise here!
5mA DC transformer - tube output stage? fyzygy Tubes / Valves 1 12th November 2011 08:56 AM
SS or tube voltage amplifying stages in an amp with tube output? ray_moth Tubes / Valves 14 4th July 2007 03:09 AM
My DIY Pre-Amplifier used 5692 and 45 Tube with output transformer cd149dc Tubes / Valves 3 3rd June 2006 04:34 PM
Output Tube biasing for Toroidal Output Transformer gingertube Tubes / Valves 7 17th April 2005 04:40 PM
toroid Transformer as output Transformer for tube preamp? tone Tubes / Valves 15 2nd February 2003 04:36 AM
