diyAudio Sponsor
Old 10th February 2012, 03:51 AM   #31
Originally Posted by chrish View Post
This data sheet may be helpful http://www.retrovox.com.au/STC807.pdf The 807 and 6L6 are from the same family of tubes, so the data will be valid.
I have uploaded STC 6L6G application report as well. 23 pages.
See http://retrovox.com.au/STC6L6G.pdf
David
Old 10th February 2012, 07:05 AM   #32
Why drive a 6L6 into A2 when the plate load is 5kohms, and b+ this low?
Old 10th February 2012, 11:24 AM   #33
dirkwright's Avatar
Originally Posted by Eli Duttman View Post
BTW, the place for a CCS in a differential gain block (LTP) is in the tail. Do not CCS load the anodes, especially if a tail CCS is used. Choke loading LTP anodes is fine.
I'm curious, can you explain why CCS is a bad idea for the loads on the LTP? It's apparently done in the tube world and it's common in the solid state one.
I agree the best place for the CCS is in the tail of the LTP.
Old 10th February 2012, 11:29 AM   #34
I can see potential problems if the CCS drift and you get serious shift in your quiescent voltages. The CCS in the tail can fight the CCSs in the plates in a way. But if you shunt the CCS with a high value resistor this shouldn't be a problem, or make sure eventual drift is common and tracks.
Old 10th February 2012, 11:32 AM   #35
Btw Maurizio, you are aware using b+ of 240volts will produce a very low output power? Usually these tubes are used with > 400V. It will work, but you'll have loudness troubles.
Old 10th February 2012, 01:57 PM   #36
dirkwright's Avatar
I don't know what others have done about this possibility, or even if it's a serious problem. I wish I knew more about circuit design.
Need help designing preamp + amplifier birdyfoot Class D 26 20th July 2011 06:02 PM
Help in Class D amplifier designing dileepkella85 Class D 39 16th March 2011 02:01 AM
help me in designing an amplifier nightcatz Chip Amps 4 22nd June 2007 06:57 AM
Page generated in 0.08001 seconds (77.45% PHP - 22.55% MySQL) with 11 queries
