help designing 6L6G S.E. amplifier
what about this?
Some important points. The 12AX7 triode lacks the ability to drive g1 of triode wired 6L6s. :( CCS loading 'FQ7 sections will push the gain up to nearly the full μ of 20 and bypass caps. on the cathode resistors can be omitted. :) The 1045S previously mentioned is fine for the CCS here.
BTW, the place for a CCS in a differential gain block (LTP) is in the tail. Do not CCS load the anodes, especially if a tail CCS is used. Choke loading LTP anodes is fine.
I'm curious, can you explain why CCS is a bad idea for the loads on the LTP? It's apparently done in the tube world and it's common in the solid state one.
I agree the best place for the CCS is in the tail of the LTP.
I can see potential problems if the CCS drift and you get serious shift in your quiescent voltages. The CCS in the tail can fight the CCSs in the plates in a way. But if you shunt the CCS with a high value resistor this shouldn't be a problem, or make sure eventual drift is common and tracks.
I don't know what others have done about this possibility, or even if it's a serious problem. I wish I knew more about circuit design.
