diyAudio Sponsor
Old 8th February 2012, 05:53 PM   #1
wicked1 is offline wicked1  United States
wicked1's Avatar
Default is 6s2p actually equiv to 8532?
Is the Soviet 6s2p actually a direct replacement for an 8532? I can't find the datasheet for the 6s2p. I've been mislead by the ebay vendors before.. (they say things are direct equivalents, when in reality the tubes have different pinouts, etc) (This is for a project w/ PCB, so pinout matters)
Old 8th February 2012, 06:12 PM   #2
Bone is offline Bone  United Kingdom
Datasheet for 6S2P here < http://scottbecker.net/tube/sheets/113/6/6S2P.pdf >
Old 8th February 2012, 06:14 PM   #3
Radiomuseum lists the 6S2P as equivalent to the 6J4, and the 6J4 as "normally replaceable slightly different" to the 8532. Which is as good as equivalent in my book. In any case the pinout, heater voltage/current etc. is the same.
Old 8th February 2012, 06:16 PM   #4
Mikha is offline Mikha  Russian Federation
Hi wicked1!
6S2P datasheet (cyirillic) is here:
ttp://istok2.com/data/65
FS: Darling Tubes 1626/8532 RockysDad Swap Meet 1 13th February 2009 02:07 AM
wtb: 8532 tubes for darling amp skyraider Swap Meet 3 4th April 2005 01:34 AM
FS... Tubes for double Darlings (1626 & 8532) RockysDad Swap Meet 2 26th January 2005 07:00 PM
need an equiv or specs... Stuart Easson Parts 0 15th September 2004 03:33 PM
Anyone done this with an LM3875 or equiv? jackinnj Solid State 2 24th November 2002 09:48 PM
Page generated in 0.07511 seconds (73.42% PHP - 26.58% MySQL) with 10 queries
