diyAudio Sponsor
Old 8th February 2012, 01:43 PM   #21
kingneb is offline kingneb  United States
I refuse to use switching regulators in tube amps. Did they have those in the 1950s, no way! Same goes for linear regulators but at least they are closer to the classic CLC power supplies. The good news is thet they reject more ripple, weigh less, are less bulky, and cost less!
I found a regulator, the LT3080, that looks to me like it allows for much more efficient operation. No 22k ohm resistors required that dissipate 3 watts each of power. Plus adding soft start is much simpler!
Old 9th February 2012, 02:06 AM   #22
jackinnj's Avatar
Didn't I say to copy a leaf from the SMPS syllabus? -- think of how you can control the loop via the primary side of the transformer. You can opto-couple the control circuitry. Controlling a volt on the primary side is like controlling 5 volts on the ouptut side.
Linear has a dozen or more designs of gate drivers, or complete packages which effect the same thing, and the late Jim Williams put out an ap-note 3 ro 4 years ago.
Old 9th February 2012, 03:45 AM   #23
TheGimp is offline TheGimp  United States
TheGimp's Avatar
Actually, they had linear regulators in 1950. They were tube based but they were linear in operation and use the same principals of modern SS linear regulators.
Would they use SS in designs in the 50s if they were available?
I know so. Manufacturers were willing to adopt Selenium stack diodes when they became a reliable technology. Same for other SS devices. It was all a cost/benefit analysis in it's basic form. There are a lot of tube amps that used solid state rectifiers once they were readily available and competitively priced.
I'm not dissing your choice to use no sand in your designs. I'm just pointing out that the technology is older than most assume. Also, manufacturers were willing to adopt whatever technology helped their designs.
Old 10th February 2012, 06:20 PM   #24
tomchr is offline tomchr  United States
tomchr's Avatar
They also had switchmode supplies "back in the day". They were called vibrators and operated at a rather low switching frequency compared to today's SMPS. Used for automotive applications among other things.
~Tom
"50 % of the game is mental and the other 50 % is being mental. I've got that part down, no problem."
http://www.neurochrome.com/audio
Old 10th February 2012, 09:50 PM   #25
jackinnj's Avatar
~Tom
One our Chryslers (old enough to remember) had a tube a.m. radio with vibrator supply.
Here's the application note on Linear's site:
http://cds.linear.com/docs/Applicati...te/an118fa.pdf
Old 11th February 2012, 09:35 AM   #26
Elvee is offline Elvee  Belgium
What I am looking for is something to prevent ON/OFF spikes, capacitive loads, etc from ruining the regulator, which riccoruder's suggessions address. Should they be sufficient or should I add something else as well?
I also am looking for short circuit protection that protect the semiconductors until a slow blow fuse in the power transformer primart can react.
Have a look at this circuit, it might be of some interest for you:
Simple HV series regulators
. .Circlophone your life !!!! . .
♫♪ My little cheap Circlophone© ♫♪
Old 11th February 2012, 09:59 AM   #27
Alain Dupont's Avatar
Ben, {kingneb }
I did build the TJC High-Voltage (Complete) for about 250/350 volts some time ago....
I did make about 3 modules for my SE 6C33C and had great results. The lowest ripple ever!
John is always bringing new idea's, and wow it's nice to see such a great site!!
Alain.
Did live about 10 years in Canada
Back to France since the 1st February 2007.
High Voltage Regulators (Maida or zener) tomchr Tubes / Valves 250 7th February 2012 05:45 PM
High voltage, high current super regulator, possible group buy peranders Group Buys 54 2nd June 2009 09:43 AM
high current vs high voltage power Clipped Car Audio 28 19th April 2007 06:06 PM
6BY5 High Voltage & High Current Choke Input Design P.S. snoopyma Tubes / Valves 7 28th June 2006 01:32 PM
high volt/high current DIY home PS. deepanger Solid State 24 13th December 2002 12:17 AM
Page generated in 0.09120 seconds (77.51% PHP - 22.49% MySQL) with 11 queries
