| diyAudio Sponsor | ||
hi,
I intend to run my pair of yahmaha B-5 amplifers 350w/4ohm per channel as monoblocks. should give 700W/Channel 8 ohm in two monoblocks. It has no bridge function, so i intend to use phase splitters using tubes , my choice is 12AU7 running on 12v Dc battery to avoid humming and noise issues and donot need much gain as it would be used only for phase splitting. Can anyone guide is it ok to do in the first place.If so where could i find a tested low voltage 12AU7 long tail time tested design. If driving the amp to full would be a problem may be i would use a dirct coupled MOSFET with constant current drain. Any help here ??? |
#2 |
P.S the amps are running mains crossed over at HP 80 Hz, so Bass roll off is not an issue here.
#3 |
If you check the Ua/Ia curves you will see that this is is a really lousy idea.
Brgds Lars |
#4 |
you mean low operating voltage for the 12AU7 ???? ok what about +/- 24 V from SMPS
#5 |
PS. Would the bridged configuration with inputs out of phase and output across hot pins of both channels would be same as the marketed "fully-balanced" monoblock amplifier and would it offer any sonic advantage like high CMMR/noise reduction etc ?
| Low voltage 12AU7 (19J6) -- re "starving" | jackinnj | Tubes / Valves | 10 | 5th May 2011 05:09 PM |
| Preamp tube SRPP 12AU7 VS preamp tube Aikido 12AU7 = all use rec 6X5GT | spiritm2r | Tubes / Valves | 1 | 6th March 2011 02:53 PM |
| Low mu triode for phase splitter | jfitz57 | Tubes / Valves | 12 | 3rd May 2010 03:11 AM |
| Phase splitter which tube? | Elektor78 | Tubes / Valves | 26 | 27th February 2009 10:55 PM |
| help whith a low voltage dc/dc converter schematic | adi109cj | Power Supplies | 2 | 6th February 2008 12:12 PM |
| Page generated in 0.07532 seconds (72.80% PHP - 27.20% MySQL) with 10 queries |
