Two diodes implies a half wave doubler. Current will be somewhat limited and in order to prevent HK breakdown you will have to elevate the second diode's filament DC potential higher then the first one. This will involve a seperate filament winding or transformer. You may also be limited in capacitor size with tube rectifiers. SS is much more pragmatic.
This is a full wave voltage doubler:
using tube dampers, i think you need 2 separate 6.3 volt windings insulated for high voltage.....this is doable....
Hi!
TV dampers work nicely. I have used them this way already. As others pointed out, watch the HK voltage. Most TV dampers have a 900V rating for heater negative against Kathode. Theoretically you can use a single heater winding for a doubler which delivers up to that voltage and have the winding connected to ground. I'd stay clear of that limit and say up to a supply delivering 600V use a single winding. Above that, two separate windings. Connect the heater of the two diodes at one side to the respective cathode in that case.
Also don't use too much capacitance after the rectifiers. 5-10uF. You will need at least a LC filter following that to get ripple down
Thomas
Thomas
Dampers
Whats key with damper tubes is the steady state peak plate current and the dc output current. The peak current is usually over 1 amp and the dc is 200 to 400ma. Used as rectifiers you need to watch the peak current on power up. You can see this in LTSpice. As you increase capacitance the peak current will exced the peak current rating. To tame this insert a 100 to 150 ohm resistor into the secondary leads.
The Greinacher, AKA "full wave", doubler is (in fact) a pair of 1/2 wave rectifiers wired back to back. To get decent regulation of the resulting rail, large caps. in the doubler stack are in order. Another poster's remarks about SS diodes being the practical solution is spot on. However, I think it may be possible to safely use damper diodes in combination with good sized caps. in the stack. Install a CL-90 inrush current limiter, whose cold resistance is 120 Ω, in the line between the center of the cap. stack and the power trafo. Perhaps as much as 150 μF. per cap. will be fine. 68 μF. parts should be "a walk in the park".
Negative temperature coefficient (NTC) thermistors are common enough in SS rectified PSUs. It seems they may be exploited in combination with vacuum diodes too.
I had good results using four damper diodes in a multiplier fed from an isolation transformer (splitting a 220 V primary that passed a hipot test for separate use of the coils). The amp used 33GY7s or 33GT7s (minor connection difference). The Op-amp driver supply used AC from a tap off the bottom filament in the string clamped with a MOV in case the tube was pulled. Screen-current-canceled cathode-sampled feedback made distortion very low even with low bias currents. Although the ability to drive grid current wasn't needed, the direct coupled feedback driver eliminated blocking distortion and the need for any adjustment or matching when changing tubes. The damper diodes and small sweep tubes share a high peak to average capability, which was a perfect fit for low bias current and music use. A reduced voltage fan was included but I didn't feel any need for it except with square wave test signals (but I keep tubes cooler than most). I admit I probably would have never used damper diodes if those tubes didn't have them included, but I really liked the result and enjoyed seeing a level of performance I once thought was impossible with junk-box tubes.
Generally the color television sets that used dampers such as the 6DW4B also had inrush current limiters. Then they were just called 120 Ohm cold thermistors. Making use of the voltage across the thermistor at start up, a degaussing coil coupled through a voltage dependent resistor (maybe a MOV?) was in parallel. That's why a sort of hum/thud surge is heard right at turn on with many c.r.t televisions and monitors. Then gently tapering down ac magnetic field takes care of tie-die color effects (beams hitting wrong phosphor segments) on magnetized c.r.t.s. Sometimes a slight wiggling of the display is seen on c.r.t monitors just as they come on while the field decays to nothing. That automatic feature is especially useful after kids have had fun with magnets near the screen. There was a comment about SPICE simulation showing a high surge for the damper tubes at turn on. While I think an inrush limiter is a good idea and it also limits the surge in cold filaments, I believe that both the specs and models don't tell the full story. Dampers are used in a mode where high peak current pulses are seen at a rate of 15.734 KHz (former U.S. NTSC system at least) and the average current is low due to the pulses being narrow (during the retrace time, the fall of the sawtooth wave for each scan line). Neither of those specs really applies to a one time surge. Plus, the current will be spread out in time some due to the cathode warming up. Hot spotting and cathode stripping issues can cause damage in some tubes seeing high currents at warm up, but neither the specs nor the models appear to be define that. I would judge dampers current capability based on two things, peak emission current based on cathode area (usually reflected by filament power, as in the different filament currents/power for the 5Y3, 5R4, 5U4, 3DG4, 6x4 6CA4 5ar4/GZ34 etc.). The second factor is thermal, estimate power loss from forward drop and current and estimate dissipation ability based on anode and bulb surface area. Thermal time constants permit large brief overloads. Longer term overloads may affect life, but few amps see as much use as 60's television sets did (there were fewer alternatives to tv then, and there were 9 minutes of ads an hour then, in contrast to the 18-20 now seen in the US) These tubes were very conservative rated in television sets and saw a very low failure rate compared to line-amp and HV rectifier tubes. Low emission was almost never seen, with most of the rare failures being arcing, perhaps from the stress of a failing line amp tube. Those often developed grid emission from contamination over time causing bias to shift and current to rise uncontrollably. I'm more of a fan of silicon diodes, saving the losses and filament power and the cost of more tube sockets. Few wasted watts leaves transformers cooler or able to deliver a bit more to something that produces output. Sometimes an intuitive understanding may tell us things the models don't.
- Power Supplies
- Damper rectifier tubes & voltage doubler
