diyAudio Sponsor
Old 5th February 2012, 02:59 AM   #1
regal is offline regal  United States
Default opt primary inductance and secondary load
Scenario. You find a 5k:8 parafeed transformer, which is rated with enough inductance at 20 hz for -3dB with an 100V signal across the primary for a 1.5kohm Ra tube with an 8 ohm speaker . Now you load this transformer with a 16 ohm driver, so the transformer presents a 10k ohm load. Good for linearity and for sake of argument the 100Vrms across the primary is good enough for the 16 ohm driver. So power went from 2W to 1W and you are OK with this.
How could this affect bass response ? I was in a debate that if I didn't parallel two 16 ohm speakers and present an 8 ohm load on the secondary that the -3dB@20hz point would shift to more than -3dB down @20hz?
I understand that increasing the load on the secondary is not going to magically increase the number of turns on the primary and give more inductance. But shouldn't the inductance stay the same independant of secondary load with the same tube Ra (assume I adjusted bias to maintain Ra) and hence the frequency response remain that same, just I lose 1/2 power by running a 16 ohm speaker on an 8 ohm tap not bass cut-off?
Old 5th February 2012, 08:56 AM   #2
Miles Prower's Avatar
Primary inductance stays the same. Connecting a lighter than rated load across it may compromise low and high frequency performance, but whether it's enough to make a big difference is another matter entirely.
There are no foxes in atheistholes
www.dolphin-hsl.com
Old 5th February 2012, 11:47 AM   #3
How would a lighter load compromise low frequency perormance? I mean with preamp OPT's (15k:600) it is common practice to drive an amp with 10k to 100k input impedance.
Old 5th February 2012, 03:13 PM   #4
The -3dB point occurs when the inductive reactance (Xl) = the parallel combo of the tube Ra and the reflected load. by increasing the value of the load the value of the parallel combo goes up pushing the -3dB point up. Quick calculations based on 10hy's of inductance put you at -3dB at 18hz for the5K load and close to 21hz for the 10K.
dave
Old 5th February 2012, 03:19 PM   #5
DF96 is offline DF96  England
+1 on the explanation, but I haven't checked the arithmetic.
Edcor GSXE10-8-5K primary Inductance? Troncones Tubes / Valves 1 12th February 2011 09:25 PM
is transformer with primary and secondary = isolation? milen007 Power Supplies 5 1st February 2011 11:30 AM
safest way to identify primary/secondary? gary h Power Supplies 15 6th January 2010 03:56 PM
Why a Zobel network across OPT primary or secondary? ray_moth Tubes / Valves 6 4th March 2005 10:26 PM
Understanding OPT primary Z and load matching. percy Tubes / Valves 4 21st August 2004 12:30 AM
Page generated in 0.08650 seconds (82.76% PHP - 17.24% MySQL) with 10 queries
